Golf mk3
hardmonkeys
immobiliser
Topic: immobiliser (Read 3271 times)
danmusic24
Re: immobiliser
Reply #10 on:
24 November 2011, 08:13 »
Your earth will be in the loom that plugs into ecu.
Deano2711
1992 VR6
Re: immobiliser
Reply #11 on:
24 November 2011, 08:25 »
I believe it finishes somewhere near the under side of the battery tray but could not be totally sure on this.
Ninja
19 smiles per gallon
Re: immobiliser
Reply #12 on:
24 November 2011, 12:10 »
So, the ECU earth runs from the loom near the engine block, under the battery tray and to the ECU near the passenger side dash.
A quick easy fix would be to simply re-wire the earth to a good earth point.
madmanmart
Re: immobiliser
Reply #13 on:
24 November 2011, 21:53 »
Yes your 1995 car will have an immobiliser.
The box mounted near the clocks is the transponder box that picks up the chip in the key.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Golf mk3
hardmonkeys
immobiliser
