Author Topic: Emts switch location  (Read 1866 times)
Offline Lurky
« on: 23 November 2011, 09:49 »
Can somebody please point me in the right directon of where the Engine managment temperature switch is located on my car please used the search function but cant seem to find what im looking for , Mk3 16v abf
Thanks
Offline Len
Re: Emts switch location
« Reply #1 on: 23 November 2011, 09:56 »
You may like to try vagcat.com as that may help.
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
« Reply #2 on: 23 November 2011, 10:43 »
engine management temperature switch?  Do you mean the fan switch?  Or the coolant temperature sensor perhaps?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #3 on: 23 November 2011, 11:07 »
Coolant temp sender is on the flange on the front of the head.
Blue or green I believe
Offline Lurky
« Reply #4 on: 23 November 2011, 11:40 »
The one that controls the ecu not the guage got some dodgy idleing when cold just trying to eliminate the problem i work in a motor factors but the system we use doesnt tell me the location just a description of the part but it gives me an option of two described as below
2 Terminals M14 x 1.5 Thread White top replaces Black or White top
or
2 Terminals M10 x 1 Thread White top
If i cant find it before i do the job ill just get both to cover myself but if i can find it it will save me ordering the two
Offline javalin
« Reply #5 on: 23 November 2011, 11:45 »
The temp sensors (at least on the 8v) are a 4 pin (which do both ecu and dash temp), sounds like these are fan switches?
James
Offline Lurky
« Reply #6 on: 23 November 2011, 11:59 »
They were on my old polo aswell but these are deffinatley emts switches  as they do list 4 different rad fan switches  :shocked:
« Reply #7 on: 23 November 2011, 12:33 »
or
Sound like oil pressure or temp maybe.
Coolant is green from memory
