Author Topic: Help revs dropping realy low wen bass drops  (Read 2557 times)
Offline ian007miles
« on: 21 November 2011, 18:48 »
I need some help. I've just been out for a boom in my car and wen the bass drops my engine revs drop realy low as if it's going to stall but the voltage does not drop.  does any one no wot this could be. I've done the big 3, 190amp altanator, Bosch s4 batery under the bonet and 2 optima yellow top battery's in the back. And a stinger split charge. Sub is a hcca 15.2 and the amp is a hcca d5000. And I'm also using an Audiocontrol epicentre concert series. The car is a mk4 golf. Thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Len
Re: Help revs dropping realy low wen bass drops
« Reply #1 on: 23 November 2011, 13:27 »
So you are saying that that your ICE system is causing the engine revs to drop? :shocked:
www.sas.org.uk
www.the-ace.org.uk
Offline ian007miles
« Reply #2 on: 23 November 2011, 18:10 »
Yes mate wen I'm heavy booming lol
Offline Len
« Reply #3 on: 25 November 2011, 09:02 »
Well I would say you have some bad connections somewhere or your alternator is knackered.
But even then it still shouldnt happen!
www.sas.org.uk
www.the-ace.org.uk
Offline danny_p
« Reply #4 on: 26 November 2011, 17:20 »
190 amp alternator is going to keep the volts up,  but it's going to be drawing some serious shaft power it's capable of putting out nearly 2.8 KW add to that the losses it has in generationg the electricity, it'll takeing about 5 - 5.5 HP to spin it.
check your cars idel valve and throttelbody as it'll be needing a lot of idel air compared to normal
all the VW's have gone bar 1.
