Author Topic: Engine hoist, what to buy?  (Read 4328 times)
Offline AudiA8Quattro
« on: 14 November 2011, 21:30 »
I'm looking at investing in one finally. Has anyone got any recommendations? what to look out for?
Do I need 1 tonne or 2 for car applications?
What the cheap ones like on ebay?
I would prefer to spend under £200.
Many thanks.
Re: Engine hoist, what to buy?
« Reply #1 on: 14 November 2011, 23:38 »
A sealey one will be fine, 1t should do the trick unless you find a 2t at a cracking price.
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 15 November 2011, 00:49 »
Probably a bit overkill for home use. They go out quite a way, but you can't put the full 2 ton on when fully extended. Each hole you slide out to is usually marked with its max load rating.
« Reply #4 on: 15 November 2011, 10:20 »
Thanks Topher.
Yes that's why i was looking at 2 tonne, as that's 500kg on full reach.
I'm not sure 250kg on full reach would be enough to move a V8 with box.
What do you think?
Offline Seanl
« Reply #5 on: 15 November 2011, 12:24 »
Think that may be pushing it a bit. Better to be safe than sorry if you can afford it.
Offline danny_p
« Reply #6 on: 15 November 2011, 23:57 »
depends on the v8 your lifting.
you'll find you rarely ever use full reach on it, to move the arm out you have to extend the legs out and i find they get in the way :(  my engine crane has developed into a couterbalance affair,   whitch mostly consists of a bolt on shelf  that sticks out back of it, that heavy stuff gets stacked so i can lift with the arm out and the legs not out so far  :smiley:
i very much dought you'll find an engine and box combo weighing over 250 KG in a car unless your dealing with big iron block v8's   my crappy sealy did manages to lift quite large commercial diesels, if you overload them the top arm just bends,  i had to make a new one for mine after trying to lift a big cummins 6
all the VW's have gone bar 1.
« Reply #7 on: 16 November 2011, 10:44 »
Cheers Danny.
The V8 is an Audi ABZ, all aluminium.
What do you think of the one in the link?
Offline Len
« Reply #8 on: 16 November 2011, 13:49 »
With some cars its easier to drop the engine out the bottom so a 2 T could lift the car up for ya!
www.sas.org.uk
www.the-ace.org.uk
« Reply #9 on: 16 November 2011, 19:51 »
So is the one in the ebay link good or sh!te?
