Author Topic: Engine hoist, what to buy?  (Read 4327 times)
Offline topher
  • Administrator
  • fully functioning
Re: Engine hoist, what to buy?
« Reply #10 on: 16 November 2011, 21:34 »
my mate has one that looks exactly like that and is awesome, but it was a lot more expensive and not imported from china.. could be worth the gamble though.
Offline AudiA8Quattro
« Reply #11 on: 16 November 2011, 21:46 »
I thought it might be worth a shot. I bought a cheap press off ebay about 6 years ago, its still going well now.
I guess if its not getting everyday use, it will last.
There isn't really any difference in price between that one and the 1 tonne ones.
So reach won't be a problem? the arm does look short on that ebay one...
Also why is it so cheap? i'm always suspicious..
Offline topher
  • Administrator
  • fully functioning
« Reply #12 on: 16 November 2011, 22:45 »
reach is no problem the legs go under the car. low cars need to be jack on to axle stands though.
we did this.. those rollers are heavier than a v8 :grin:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #13 on: 16 November 2011, 23:12 »
i have a sealey 2tonne one i picked up on gumtree for £80  :cool:
« Reply #14 on: 17 November 2011, 00:09 »
So the verdict is, buy the ebay one?
Offline danny_p
« Reply #15 on: 17 November 2011, 00:19 »
ebay one looks optimal to me
all the VW's have gone bar 1.
« Reply #16 on: 17 November 2011, 20:37 »
Thanks guys.
What do people use to attach to the engine? just a chain?
Offline Len
« Reply #17 on: 17 November 2011, 20:48 »
Looks OK to me! I have hired worse! :laugh:
But then I have also taken an engine out by twisting a rope! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline danny_p
« Reply #18 on: 17 November 2011, 20:59 »
my prefered lifting weapons are old seatbelts,   ratchet straps and chain.
what you really need is a meter or so of really good chain with links big enough to get a bolt and or D shackel through then youo can ether put d hook through the chain and engine lifting eye or  put a bolt through the chain and into the engine, or wrap the chain around things and lift if needs must.
i lift a lot of engines out on the head bolts after pulling the head to find out what went wrong you realise the lifting eye was bolted to the head,
i allways find the small ratchet strap is usefull to adjust the tilt of the engine if working on your own on a tricky one wee the engine needs to be tilted and rotated to perswade it to fit in the hole.
seatblets mainly the middel lap belt just make good quick relese slings mainly for picking and moveing stuff about with
« Reply #19 on: 17 November 2011, 21:26 »
Thanks again.
Danny, i think a chain would be best bet, where's the best place to buy?
