Author Topic: squealing noise  (Read 1888 times)
Offline mason001
squealing noise
« on: 14 November 2011, 18:02 »
hey guys,
my mk4 gti makes a squealing type noise for a second after i start the car, sounds like some sort of belt or something but i have no idea about engine side of things.
any help would be much appreciated.
cheers.
Offline sharki786
  • GOT BOOST??
Re: squealing noise
« Reply #1 on: 14 November 2011, 18:53 »
theres a thread on how to in the mk4 section under the maintnance section. (starter motor making a squealing noise) or the aux/alternator belt may need replacing or is loose
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mason001
Re: squealing noise
« Reply #2 on: 14 November 2011, 19:10 »
ah lovely, cheers bud
Offline Screech16v
  • MK3 20vt AGU
Re: squealing noise
« Reply #3 on: 16 November 2011, 19:14 »
Bearing gone in the starter motor. :smiley:
Offline AshP
Re: squealing noise
« Reply #4 on: 20 November 2011, 17:34 »
mine did this starter motor fix guide is excellent  :smiley:
Offline pickles
  • Next!!!
Re: squealing noise
« Reply #5 on: 15 December 2011, 00:36 »
as above, get it whipped out stripped down and regreased, then hopefully that should sort it :)
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Re: squealing noise
« Reply #6 on: 16 December 2011, 21:04 »
Sounds more like the alternator belt slipping, check it's adjustment
