Author Topic: Vr6 clocks rev guage mis-reading  (Read 2273 times)
Offline leigh_harty
  • Audi AGU
« on: 13 November 2011, 17:28 »
Just picked up a vr6, all good apart from the clocks mis-reading.
Says the car idling at 1100ish but i know this to be untrue - should be around 650rpm
The speedo redlines... goes straight through... stops... but the car still pulling
The guy says the clocks have been changed, Would gti clocks cause this problem as i know they arent made for 6cylinder engines
Thanks, Leigh
Dont lose your dinosaur!
Offline dom
  • Back in a Mk4
Re: Vr6 clocks rev guage mis-reading
« Reply #1 on: 13 November 2011, 17:58 »
Idle should be around 1000ish :huh:
Offline leigh_harty
  • Audi AGU
« Reply #2 on: 13 November 2011, 18:04 »
My last one was around 650rpm?
And when you did the clock trick thing and it showed you the rpm of the screen it matched?
Either way if the rpm is fine then still revving further than the clocks go  :grin:
Offline dom
  • Back in a Mk4
« Reply #3 on: 13 November 2011, 18:10 »
Are they 140mph clocks? If so then they are the wrong ones :wink:
Offline leigh_harty
  • Audi AGU
« Reply #4 on: 13 November 2011, 18:29 »
Haha didnt think to go out and look at that! DOH  :grin:
Offline leigh_harty
  • Audi AGU
« Reply #5 on: 13 November 2011, 18:32 »
160 clocks  :undecided:
Offline Bellend
« Reply #6 on: 13 November 2011, 18:41 »
Could be 16V ones.......
Where all my moneys went.
Offline tweed
« Reply #7 on: 13 November 2011, 19:21 »
99% sure they are 16v clocks you have
and a cold vr6 will idle at 1100 rpm then drop to 850/900
Offline leigh_harty
  • Audi AGU
« Reply #8 on: 13 November 2011, 19:42 »
Yeah maybe, he did say he had a problem with the last set of clocks.. the fuel guage didnt work. Maybe theres something in that then!
I know somebody with vr6 clocks so ill have a play this week after ive stopped giving it the beans everywhere  :laugh:
« Reply #9 on: 13 November 2011, 20:38 »
650rpm is way too low, around 850 is correct.
Sounds like you have 4 cylinder clocks fitted.
