Author Topic: N75 Valve and tuning  (Read 7135 times)
Offline Ant1981
  • Feed me, prod me
« on: 09 November 2011, 16:25 »
I need to replace my N75, but which should I go for? There's the J version, the K version and a few others, which really would be good for after stage 1?
'09 Kawasaki Ninja ZX-6R
Offline dom
  • Back in a Mk4
Re: N75 Valve and tuning
« Reply #1 on: 09 November 2011, 16:31 »
Depends on the Map, Carbon maps work better with the J version, other maps differ :wink:
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #2 on: 09 November 2011, 17:38 »
If it was mapped for a standard valve, fit that. As Dom says if you want to go further with tuning it will be down to the mapper after that but you can't just throw anything in at the mo :smiley:
Offline Chris.
« Reply #3 on: 09 November 2011, 20:01 »
Id go for latest revision!
Click For Build Thread
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #4 on: 10 November 2011, 21:35 »
I hear the latest revision makes your tappets rattle  :undecided:
Offline Chris.
« Reply #5 on: 10 November 2011, 22:13 »
Could always get a 'J' Valve and have overboost :|
Offline The Doc
« Reply #6 on: 10 November 2011, 22:46 »
Which can be seen clearly giving issue in the graph of a carbon map using the N75J below?
« Last Edit: 10 November 2011, 22:58 by The Doc »
Offline The Doc
« Reply #7 on: 12 November 2011, 19:01 »
I hear they work much better when the owner plumbs them in the right way around  :laugh:
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 12 November 2011, 19:54 »
I spoke to R Tec and they said to use nothing other than what was meant for my car.
Offline dom
  • Back in a Mk4
« Reply #9 on: 12 November 2011, 19:56 »
Tw@t :kiss:
Which is what has already has already been said, my car is mapped for a J valve, unless your car is mapped specifically for J then stick with standard!
