Author Topic: Noisy Idle - failing flywheel?  (Read 3169 times)
Offline Marlowe
« on: 07 November 2011, 15:35 »
Just after the thoughts of anyone more knowledgeable on the inner workings of the GTI (ie anyone here :P) to bounce ideas off.
The golf's increasingly developed a low rattle at idle. At first I thought the foam had shifted from my fuel line rattle, but that wasn't the case.
Then I noticed that the noise fades when I depress the clutch. Does this mean I'm probably looking at a new flywheel, or could there be something simple I'm overlooking (it wouldn't be the first time)?
Thanks in advance. :)
Offline _Adam_
Re: Noisy Idle - failing flywheel?
« Reply #1 on: 09 November 2011, 10:04 »
exactly the same problem for 2 years on mine. I find if its rattling, I put in gear and raise to bite point whilst on the brake, then out of gear and off the pedals and it goes a bit quieter.
would love to know what it is
Offline sprout99
« Reply #2 on: 10 November 2011, 07:33 »
Concentric slave cylinder - it's a gearbox out job if it bothers you that much
they do rattle as they get old. Pressing clutch and releasing etc can get it to settle down
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline _Adam_
« Reply #3 on: 10 November 2011, 12:10 »
replacement part or just a good clean?
Offline sprout99
« Reply #4 on: 10 November 2011, 12:16 »
replacing means gearbox out so might as well do clutch too !!!
Oak green mk2
V50 D5 Sportwagon
Offline Marlowe
« Reply #5 on: 08 December 2011, 00:35 »
Bugger. Cheers. Slave cylinder seems to come as an all in one with clutch release bearing, so sadly a full clutch job as you say!
It's also developed a more noticeable secondary idle at low revs & gas (such as when pulling away from stationary) which I suspect might be the bearing starting to go too - looks like it's getting to that time... :(
