Author Topic: MOT time 2moz :(  (Read 8546 times)
Offline Milby
Re: MOT time 2moz :(
« Reply #20 on: 04 November 2011, 19:29 »
yeh has drums at back so il get them checked :)
MK3 Golf 1.4 SE ;)
Offline mush
« Reply #21 on: 05 November 2011, 10:15 »
16v reporting in
FAILED its MOT
list as follows
side light gone - New bulb
ABS light issue - New Sensor
Fuel Cap issues not sealing properley - New filler neck
shouldnt cost me to much and the garage that does
all the work are amazing on price and do a good job.
MK2 golf 16v :-)
Offline stainesy
« Reply #22 on: 05 November 2011, 16:07 »
16v reporting in
FAILED its MOT
list as follows
Speaking of filler cat not sealing. I have noticed on mine when I put her in the garage at night or after a long drive and turn the engine off my fuel cap makes a constant pressure releasing sound like a whistle. Is that normal?
Offline Seanl
« Reply #23 on: 07 November 2011, 15:34 »
Just got back from mine, - FAIL!
Not at all bad though which I'm glad. I had a side light out too (which I should have noticed)  :rolleyes:, and I need a new passanger headlight if anyone has one going spare for a few beer tokens!? This was because it was quite far off and the adjustment mech has was snapped. I joey'd my lights a while back, and I put them in the oven for a few minutes to break the seal. Needless to say, I left it in a bit too long and it melted.  :embarassed:. Anyway not an expensive fix, so get this all sorted and another years ticket. No advisories either so bonus really.  :smiley:
Offline mush
« Reply #24 on: 08 November 2011, 17:31 »
glad it isnt going to cost to much sean.
WELL mine on the other hand LOL.........the ABS sensors needed are both rears, however i had a call from the gagrage today said their replacing the sensors but theres another fault code coming up (ABS pump failing) which is major bucks if its ecu related :(
i'm going to have a cry about my bank balance tonight and more
due to the fact i'm spending my motorbike money saved for
a year,
i'm so bobed off but i blew my whistle before directing the traffic  :cry: :cry:
MK2 golf 16v :-)
Offline mush
« Reply #25 on: 08 November 2011, 17:45 »
16v reporting in
FAILED its MOT
list as follows
I believe its normal stainsey will just be vacuum pressure, you'll notice it more when you've had your foot planted on a long journey or if you sit on the redline like me   :grin:
MK2 golf 16v :-)
Offline tweed
« Reply #26 on: 08 November 2011, 17:47 »
people putting lights in the oven  :laugh:
use a heat gun  :wink: takes two minutes and only the glass will get hot.
good luck with ya cars
Offline Seanl
« Reply #27 on: 08 November 2011, 18:58 »
Yeah yeah, u laugh at my expense but........but...........
Ok I've got no comeback. :sad: :tongue:
Offline CM690
  • Golf MK4
« Reply #28 on: 08 November 2011, 20:41 »
Got my car back from it's MOT today, failed as expected :grin:
Only a few things though, rear wheel bearing, number light out (I should have noticed that), CV gator didn't have a clip on it.. o.O other than that it's not too bad apparently!  :evil:
Offline mush
« Reply #29 on: 09 November 2011, 14:14 »
ok garage have called x2 sensors replaced and now coming up with ABS pump failing.
next question is does anyone have the part number for this?
MK2 golf 16v :-)
