Author Topic: MOT time 2moz :(  (Read 8570 times)
Offline mush
Re: MOT time 2moz :(
« Reply #10 on: 04 November 2011, 10:14 »
Good luck :afro:
Yep :afro:
Look on the bright side, mine went in on Tuesday for it's mot and I still have not got it back yet  :shocked:
thanks just got a bad feeling this time round,
good luck for yours wayne,
MK2 golf 16v :-)
Offline Bellend
« Reply #11 on: 04 November 2011, 10:21 »
What's wrong with MOT times?  :lipsrsealed: :grin:
How did you adjust the handbrake btw?
well just dropped her off,
adjustment's from inside the car , remove the rear ash tray and you'll find two screws holding the plastic
handbrake cover on, remove cover and pull off, youll see the adjusting srcrews now.
from memory use a 10mm spanner to losen off nut that sits agaisnt the other adjuster nut and there you go very
easy.
make sure when youve adjusted the cables they pull even on both sides, also note: dont do it so tight
it snaps your cable/s when you pull up on the handbrake (or you'll be back on here giving me grief LOL)
think with mk3's you should be getting 2 clicks or 3 at the max.
very early for me today so hope this makes sense  :smiley: :laugh:
Ah right.  Just that's not the proper way really mate. You need to take the drums off and adjust the shoes, just tightening the cables makes the shoes wear uneven.
Where all my moneys went.
Offline mush
« Reply #12 on: 04 November 2011, 10:48 »
easy.
agreed, its just for rear disc. drums a different melody
MK2 golf 16v :-)
Offline Milby
« Reply #13 on: 04 November 2011, 12:03 »
mine failed on tyres so got them redone :) am skint now :(
MK3 Golf 1.4 SE ;)
Offline Milby
« Reply #14 on: 04 November 2011, 17:13 »
Few Advisories
- Rear wheel bearings have slight play
- Both trailing arm rubber bush deteriorated
- CV gaiter deteriorated
so few jobs to get done :)
MK3 Golf 1.4 SE ;)
Offline LowlifeDubber
« Reply #15 on: 04 November 2011, 18:40 »
Wheel bearings £20 the pair.
2 new wishbones £40 the pair
CV boot  £8
3 cups of tea   £1
Jobs a gudn :cool:
Offline Milby
« Reply #16 on: 04 November 2011, 18:43 »
tidayyyyy ;)
how easy are they all to fit :)
MK3 Golf 1.4 SE ;)
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 04 November 2011, 19:01 »
Few Advisories
1- easy enough
2- labourious ball ache but not complicated
3- simple enough if your shaft aint glued into the hub  :smiley:
Offline Milby
« Reply #18 on: 04 November 2011, 19:04 »
better get on with it as soon as i have some money :) i'l get some of my mechanic friends to give ma hand :)
MK3 Golf 1.4 SE ;)
Offline Bellend
« Reply #19 on: 04 November 2011, 19:28 »
Get your mechanic friend to check the bearings are gone as one MOT tester I know always advises them but if it has drums at the back, these types of bearings naturally have a bit of play and is allowed.
