Author Topic: stage 2 ko3s  (Read 4032 times)
Offline porter_89
stage 2 ko3s
« on: 02 November 2011, 21:08 »
Hey guys I got a set of bam injectors and was wondering if it's worth putting them.on a stage 2 golf with ko3s or just keep the aum ones
1.8t-aum-stage 1 remap wagen worx-CAI-demon motorsport TIP-black forge 007P,H.I.D's 6000k-front badgless bonnet bra-r32 reps(selling soon)-m3 rear lights,dropped on JOM coilovers with fk drop links-3" turbo back exhaust-FMIC ordered SOLD SOLD SOLD
to do:
Bbs lm reps want now haha r32 wheels for sale soon pm me if interested
Offline porter_89
Re: stage 2 ko3s
« Reply #1 on: 03 November 2011, 10:50 »
anyone whats the benifits with the injectors if none im selling them
cheers
to do:
Offline porter_89
Re: stage 2 ko3s
« Reply #2 on: 12 November 2011, 13:25 »
No one please should I.use these or not im just looking at next stage on turbo I got for now
to do:
Offline shaft69
Re: stage 2 ko3s
« Reply #3 on: 12 November 2011, 15:27 »
Looking to have stage 2 map as well, your spec similar to mine but I have 3"APR down pipe with sports cat and full milltek system. Mine running APR map which is pretty awesome. Will be interested if stage 2 map would benefit from larger injectors.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline porter_89
Re: stage 2 ko3s
« Reply #4 on: 13 November 2011, 12:51 »
i just fitted mine now runs ok not lumpy as i thought so im leaving them in and going for it
to do:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: stage 2 ko3s
« Reply #5 on: 13 November 2011, 19:45 »
Your fuel trims will be way out and could be washing the bores under load conditions which can make the oil weak, the bigger injectors need to be mapped in just the same when going for a 4 bar fuel reg.  If you log blocks 32 you will find your fuel trim MULT/ADD adaptions are hitting the upper limits.
Your best bet is leave them until you take it for mapping then you can get them setup correct, Get the map changed the fitting the injectors.  To change the AUM map for bigger injectors is only a 5 min job, just need to adjust the 1x1 KRKTE - primary fueling constant map for the 380cc flow rate then the whole map will be spot on fuel wise.
 01455 617233
Offline porter_89
Re: stage 2 ko3s
« Reply #6 on: 13 November 2011, 20:50 »
so am i doing major damage to the car as there aint no roughness ectect i got vcds lite can i do it opn there?? aint dave iow running different injectors and maf without map changes??
cheers
to do:
Offline RTechUK
Re: stage 2 ko3s
« Reply #7 on: 13 November 2011, 21:26 »
Not the same ecus..
AGUs can be offset with bigger maf % to go with injectors.
 01455 617233
Offline porter_89
Re: stage 2 ko3s
« Reply #8 on: 13 November 2011, 21:29 »
so am i doing damage am i or just overfueling??
cheers
to do:
Offline RTechUK
Re: stage 2 ko3s
« Reply #9 on: 13 November 2011, 21:37 »
cheers
Overfueling which can wash in to the oil and cause issues, the power will be less as you will be running far to rich top end when the car reverts to the lambda protection maps.  There are no gain to be had by fitting bigger injectors / 4 bar fuel reg without making map changes.
The stock AUM injectors will flow to a little under 265bhp maxed out.
 01455 617233
