Author Topic: What happens if?  (Read 2084 times)
Offline CarlGallagher
What happens if?
« on: 31 October 2011, 10:14 »
Im 95% sure my ICM unit has fried on my 1999 1.8T, car will have bad idle(very up down not actually stalled yet though) and decreased power going through the gears. Ive ordered a new one from ebay but im wondering what effect it will have on the car if i keep driving it in current state.
I came to above conclusion by reading other posts, previous owner fitted K&N ind kit so the ICM was just left floating around in the bay (guys a tool) when it was attached to side of air box to prevent over heating i recon.
Any tips on this would be awesome as all ive had is problems with my new golf so far all cheap fixes though which is ideal. If any one has had the same problem where did you relocate the ICM unit to keep cool?
Thanks
Offline daz veedub
  • Operation 1.8t bolf
Re: What happens if?
« Reply #1 on: 31 October 2011, 10:24 »
mines always been cabletied to plastic box behind airbox ,still there now even tho ive refitted original airbox
« Reply #2 on: 31 October 2011, 11:02 »
I have the normal air box thinking of just fitting it back to standard not really sure my dirty old cone is doing much tbh. Theres a bit under were the airbox was i think its the wheel arch Bosch say the unit should be glued using heat conductive paste to some thing cooling ie air box or some thing simelar i think that will do nicely.
Has yours ever over heated?
Offline daz veedub
« Reply #3 on: 31 October 2011, 11:06 »
touch wood  :wink: never had any problems i was running pipercross induction kit and cabletied it on then decided to smooth the airbox and fit pipercross panel and left the icm where it was
« Reply #4 on: 31 October 2011, 11:14 »
What do you mean smooth the air box?
Offline barrym381
« Reply #5 on: 31 October 2011, 11:18 »
http://www.golfgtiforum.co.uk/index.php?topic=87356.0
think this will help with smoothin the airbox
« Reply #6 on: 31 October 2011, 11:34 »
Thanks for the link looks pretty easy to do, currently have a K&N fitted do you think i smooth the air box it would be worth putting the air box back on or sticking with the K&N?
Offline barrym381
« Reply #7 on: 31 October 2011, 12:11 »
im sure the k&N filters dont do them any good is it a panel filter or cone
« Reply #8 on: 31 October 2011, 12:31 »
Its the cone version, really dirty i ordered the cleaning stuff but its not arrived yet
Offline barrym381
« Reply #9 on: 31 October 2011, 13:15 »
think its the oil in those filters thats the prob personally i would go back to standard or a decent panel filter
