Author Topic: Fog light loom  (Read 3278 times)
Offline sellers
  • Daz Works in Health and Beauty
Fog light loom
« on: 30 April 2005, 12:04 »
I was wondering where the fog light loom for front fog lights go? iv just bought one and i havent got it yet but was wondering wheather it goes from the fogs to the fusebox or to the switch or both?
GTi joe its your que to reply, lol
Can't think of a funy or whitty comment
Offline Mr Blue
Re: Fog light loom
« Reply #1 on: 30 April 2005, 12:44 »
fogs only work when the front lights are on so im guessing they connect to the light switch, the fog switch and the fuse box?
I would just run a (-) directly to one terminal of the fogs then a (+) to the switch with an 'In-Line' fuse or something similar?
A basic bulb loom with a switch and fuse if your with me
You can get the connectors from the scrappy. Bumper indicator plugs can fit
« Last Edit: 30 April 2005, 12:46 by Blue Mk2 »
Offline takethefifth
Re: Fog light loom
« Reply #2 on: 30 April 2005, 13:49 »
Just recieved my loom yesterday, not installed it yet but from my original thread about fitting foglights (you might want to check it)......
There is apparently a connection for the front fog lights already in the golf located under the expansion tank. The loom i have recieved bears out this so it should all just fit together when i get round to sorting this tomorrow.
No wiring, just plug and play  - love it  :laugh:
Re: Fog light loom
« Reply #3 on: 30 April 2005, 14:38 »
Just checked under my bonnet and the connector is a white plastic one at the back of the engine bay on the right underneath your water expansion tank. Corresponds perfectly with the loom i had delivered. Hope this helps  :wink:
Offline Dizzie
  • Make friends with your fast
Re: Fog light loom
« Reply #4 on: 30 April 2005, 15:25 »
remember not to use them unless it's actually foggy else you'll be just another chav ;)
Offline sellers
Re: Fog light loom
« Reply #5 on: 30 April 2005, 20:56 »
oops, well i may have to test them out for the 1st week but after that the chaviness will go
Re: Fog light loom
« Reply #6 on: 30 April 2005, 21:02 »
HAHA right - note to newbies like myself - Make sure you check your facts before posting them!!!
Well Mr Sellers... I was all excited about finding WHAT I THOUGHT was the right connector only to get home and check and find it was not, by a mile!!!
The actual connector is right at the back coming through the bulk head, is white plastic, small and two connectors to marry perfectly with your loom connector. Took me ten minutes to find the little bugger though!
Also check to make sure you have a fuse in the foglights fuse thing (6th from the left), i didn't have one in there and spent another ten mins with a multimeter wondering if my loom was faulty. Stuck a fuse in and away they shone. (10amp)  I assume cars that originally came without front fogs had no fuse as they didn't need one.
Hopefully this will actually be help now rather than hinderance!!
Offline redders
  • 88 8V GTI, 3dr helios blue
Re: Fog light loom
« Reply #7 on: 30 April 2005, 21:39 »
maybe dizzie could make some .......or has that been done before.....hmmmm :grin:
Re: Fog light loom
« Reply #8 on: 30 April 2005, 22:49 »
After the quality of the loom i got,  if i hadn't been able to get one from the breakers so easily i was considering asking!!   :laugh:
Quality work Dizzie!  :smiley:
Offline sellers
Re: Fog light loom
« Reply #9 on: 01 May 2005, 00:01 »
so what are you telling me, lol :laugh:
are you saying even though mines only a diver that i already have a fog light loom hidden somewhere and therefore i done need to buy one?
