Golf mk2
Fog light loom
Topic: Fog light loom (Read 3297 times)
takethefifth
Re: Fog light loom
Reply #10 on:
01 May 2005, 02:44 »
Ah! didn't realise it was a driver... not worked on one so i am not sure. If its the same as the gti then by my understanding you already have a connector for the front fogs under the expansion tank but you need a loom to get from the connector to the lamps. Like the one that i have just got and works a treat.
Have a look for the plug and check it with a multimeter to make sure. If not then hmmmmm......
www.tt5th.co.uk
sellers
Daz Works in Health and Beauty
Re: Fog light loom
Reply #11 on:
01 May 2005, 09:38 »
o rite, well i'll have a look today for it
Can't think of a funy or whitty comment
sellers
Re: Fog light loom
Reply #12 on:
01 May 2005, 15:00 »
just looked now and i have one white connector under the expansion tank area, an di have tested it on the multimeter and sure enough it switches on with the fogs, is it only one connector that i need to find or is there one for the other side
takethefifth
Re: Fog light loom
Reply #13 on:
01 May 2005, 18:47 »
Sweet! yep that one connector is all you need. The loom plugs in and has two wires leading off to the respective fogs.
With one eye on the weather i think i am going to attempt putting mine in tomorrow. Wish me luck...!!
www.tt5th.co.uk
sellers
Re: Fog light loom
Reply #14 on:
01 May 2005, 19:18 »
good look mate, thanx for that info makes it a piece of p*ss now, mint
just need to get a loom now
...joe
Forum Supporter
Forum addict
Re: Fog light loom
Reply #15 on:
01 May 2005, 22:02 »
^^ see i knew you'd be fine without my help!!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
sellers
Re: Fog light loom
Reply #16 on:
01 May 2005, 22:09 »
Quote from: gtijoe on 01 May 2005, 22:02
lmao
And I thought the famous gti joe was expanding on the points of everyone else with his expert knowledge and his degree in all things MK2
...joe
Forum Supporter
Forum addict
Re: Fog light loom
Reply #17 on:
01 May 2005, 22:17 »
famous?! you flatter me sir!!! ok expanding on whats been said errrrr.............the wires on the plug coming out the loom are brown and white ........... i think!!
sellers
Re: Fog light loom
Reply #18 on:
01 May 2005, 22:55 »
lol, you see i knew you could do it
takethefifth
Re: Fog light loom
Reply #19 on:
02 May 2005, 21:38 »
And finally its done! Took me a bit of logical thinking to figure out which way those bloomin brackets went though!
Thanks for help everyone!
www.tt5th.co.uk
Golf mk2
Fog light loom
