Author Topic: my mk3 broke down -lost my spark ): FIXED !  (Read 2784 times)
Offline spudboy6
  • Just like a golf ......
« on: 25 October 2011, 22:27 »
was driving along , in heavy heavy rain . the car gave the impression of running out of fuel .... that juddering then running then cut out then judder and then stopped dead .
i tried to re-start it and the rev's build up slowly and i can smell the fuel .
got out and chacket the dizzy , nice and dry all looks okay , no plugs have fallen off sensors .... nothing obvious . got it back home got a ht lead off . bam , no spark.
fuse's inside the car are all okay but un-sure where the other bay fuse's are on the 1.4 AEX .
so ive got no spark , i replaced the dizzy cap and arm 20K ago because it gave me these problems before but the plug fell out the back of the ignition barrel . but thats okay this time .
has anyone got any experiences or ideas on what this is ?
« Last Edit: 27 October 2011, 23:30 by spudboy6 »
VW BUSH
Re: my mk3 broke down -lost my spark ):
« Reply #1 on: 25 October 2011, 22:28 »
Ignition module
Offline spudboy6
« Reply #2 on: 25 October 2011, 22:29 »
is that also known as the coil pack ? , sorry to sound dim ! ,
VW BUSH
« Reply #3 on: 25 October 2011, 22:36 »
Yes, common fault on Mk3 could be other things but they do go funny real quick when they start to break down.
Offline spudboy6
« Reply #4 on: 26 October 2011, 13:57 »
have a signal from the sensor on the dizzy , and have 12V at the coil ?:@ ,. still qwont start no spark from the king lead but there is 12V to the coil and an earth , but no trigger to the coil :S
Offline Khare
  • The bear that khares
« Reply #5 on: 26 October 2011, 14:02 »
Replace the coil. Mine did the same and it turned out to be the coil. You can buy a used one for £10-£20 like I did but as with mine it lasted only a handful of months. Eventually I splashed out £80 for a new coilpack from the RAC (but genuine VW) and that included 12 months warranty, been perfect since  :smiley:
Offline kahunajb
« Reply #6 on: 26 October 2011, 14:14 »
Could be crank sensor mine went recently with similar symptoms. Would see if you could borrow a coil first to rule that out tho.
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline Seanl
« Reply #7 on: 26 October 2011, 15:43 »
I had this Monday. Had to get a Taxi to work, but got let off work to go and sort it (boss is awsome!) so went back about 2 hours later, and it started first time. I suspected coil/dizzy/leads and I had spares of all these but obviously were'nt needed. Dont rule out the dizzy just cos it looked dry, and was replaced what is actually quite a while ago now. The slightest bit of moisture inside could have a big effect on its performance. They're less than a tenner anyway, so may well be worth swapping it about to rule it out.
Offline madmanmart
« Reply #8 on: 27 October 2011, 18:48 »
Coil or leads.
Ive got a few coils if you need one.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline spudboy6
« Reply #9 on: 27 October 2011, 23:29 »
my hat of to you guys ! the coil has bracked on the back against the bulk head despite giving me a reading on the old avo it was naff'ed ! all fixed now thanks guys !
