Author Topic: Sticky Lifters 1.8T?  (Read 12841 times)
Offline Chris.
Re: Sticky Lifters 1.8T?
« Reply #30 on: 26 October 2011, 22:20 »
So 7500+RPM is a killer?
7200rpm rev limter.  Might get it knocked down to 6950ish looking at the graph from dyno.
No updates.  Got same sat on but need to put the piston #1 at top dead centre and line cams up.  had a quick look today but lining the timing marks up on cams with 16 teeth puts the cam sprocket not on top dead centre....SO....when you time the head up, do you rotate the cams around so the sprocket is at top dead centre?
Luckily we have a AGU in the garage so I can easy check things.  If it doesnt go well...tomorrow ill be swapping engine for that and finding out whats wrong with mine.  Mates clio project can wait!
please, information on timing as I only had a quick look at it today between jobs.
Click For Build Thread
Offline Chris.
« Reply #31 on: 27 October 2011, 21:48 »
Got it built back up tonight with tappet swapped over.  Still no luck and still tapping its tits off from same area.  Head off and inspection and see what cause is.
Could be putting mates engine in aswell depending what the problem is.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #32 on: 28 October 2011, 13:55 »
damn not a good result then
where is the tapping coming from mate? Could it be the cam chain?
Offline Chris.
« Reply #33 on: 28 October 2011, 13:57 »
No idea.  Early indications show its not head related from
Machinists but he wants tappets to see what they like.  So could be bottom end so whipping sump of later on and check pickup.
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #34 on: 28 October 2011, 14:09 »
bummer mate them chain rentioners can make a noise my mates first golf have a noisey tentioner. so when nick does mine shall i get him to put the limiter at 7k rpm? also yours is running a mbc do i need one as well?
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline Chris.
« Reply #35 on: 28 October 2011, 23:06 »
Im not overly too sure what issue is yet.
When we psuhed the car back tonight in gear, the 4th cylinder filled with oil.....whether this was because engine was in reverse and pushing oil up I dont know  but its now a bare block and I have replacement ready to fork lift in tomorrow at some point.
If its a rod, chances are ill just buy a set of uprated ones and set of piston rings and rebuild my engine and swap back over.  Otherwise, mate is going to have my 'dead' one to put rods in.
Could well be the torque has killed them, Albeit a bit under 300lb/ft torque, but with a engine on 102k who knows what they like/torque they can cope with.
One thing we did notice was there was a white/clean line around the 4th cylinder exhaust valve on the end and the others were just normally coked up as they do....just this one had a line around outside it....i didnt see it though, just mate explained.
If i was to do it again, id get rpm limited to around 6950/7000 if you want to sound cool with a 7 in your rev limiter.  You just need to see my graph to see how much power drops off over 6800rpm.  Definately drops from about 190bhp @ 6800rpm to ~140bhp @ 7200rpm, so just shows the sheer lack of power the turbos can give at high RPM!
I have a MBC to cap the peak boost
Offline tshirt2k
  • Been there...Done that...
« Reply #36 on: 29 October 2011, 08:10 »
Oh dear! So much for that pushing that lil' ko3s to its limits.  :lipsrsealed:
Mk3 ABF 16VT Megasquirt V3
Offline Chris.
« Reply #37 on: 29 October 2011, 11:15 »
Engine trouble isnt related to turbo ;)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #38 on: 29 October 2011, 11:17 »
Helpful as ever. If you hadn't noticed it's an engine problem not a turbo problem so be a good man and kindly piss off :afro:
Offline Chris.
« Reply #39 on: 29 October 2011, 11:18 »
:laugh:
