Author Topic: Sticky Lifters 1.8T?  (Read 12824 times)
Offline Chris.
Re: Sticky Lifters 1.8T?
« Reply #10 on: 24 October 2011, 10:05 »
Will check pickup later on.
Nick -  still dropping into limp mode when at 4000.  Will get a fault scan done see if anything popped up!
Click For Build Thread
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #11 on: 24 October 2011, 10:35 »
Are you still running the MBC? as you will need to set it correct, Get another boost gauge and set to 21/22psi peak with the MBC then the N75 will do the rest.
 01455 617233
Offline Chris.
« Reply #12 on: 24 October 2011, 10:52 »
MBC in parallel.  I'm seeing 18psi peak on my gauge so around 21psi. MBC is capped where you set it.
Will try find another boost gauge
Offline RTechUK
« Reply #13 on: 24 October 2011, 11:33 »
It will need setting up again as when in parallel there is extra bleed off from the n75, unlike running it on its own.
 01455 617233
Offline Chris.
« Reply #14 on: 24 October 2011, 12:35 »
Ahh. Makes sense.  Going to fault code scan it now and see what comes up!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 24 October 2011, 19:19 »
I'll go and get the biscuits, watching this with great interest  :smiley:
Offline Chris.
« Reply #16 on: 24 October 2011, 19:25 »
Checked cams today and no unusual wear.  Going to check pickup tomorrow and maybe new oil and a flush to try clear things out?  What you think?
« Reply #17 on: 24 October 2011, 21:36 »
I would not use engine flush tbh :smiley:
Offline Chris.
« Reply #18 on: 24 October 2011, 21:38 »
What would you recommend?
Heard a few good things about forte stufff....but all it does is dislodge any grime in oilways potentially causing a blockage.
Theres a couple options:
1) ignore it and hope it wears off
2) fresh oil and clean pickup
3) New exhaust tappets
« Reply #19 on: 24 October 2011, 21:46 »
Option 2 but fit a new pick up pipe for what is costs.
