Author Topic: in for service tomorrow and something wrong today  (Read 4741 times)
Offline vw spur
« on: 21 October 2011, 17:51 »
great, i am booked in for a service tomorrow at vw and just as i get home my car starts playing up.
its a 2006 golf gti, i parked on my drive and on idle the revs were going low and then rising again, the car seemed a little shaky
had the coil packs replaced 2 months ago and have only had it 3 months
would anybody have an idea what may be the matter plz
Collected 09/04/16 : Golf GTD Carbon Grey Sport & Sound Pack DSG Pro Nav Dynaudio Rear Camera High Beam Assist 90% Tints
Still pining for:2009 BMW 330i M Sport Convertible
Offline vw spur
Re: in for service tomorrow and something wrong today
« Reply #1 on: 22 October 2011, 13:56 »
well had the rac out to it this moring, he said it could be coil pack problem(had all 4 replaced in august). what are faulty coil pack symptoms???? he also followed done a diagnostic check which showed no fault codes.
he also followed me to vw in doncaster, in which time the car drove fine but still was up and down on idle and seemed hesitant in 1st and 2nd gear. VW said they would not have time to look into that problem in depth but they also doe a diagnostics check as part of the service, which again showed no faults.
could it possibly be a coil pack problem causing the idleing problems???
Offline trizza
« Reply #2 on: 22 October 2011, 14:35 »
PCV?  Mine went and it had similar symptoms
Offline vw spur
« Reply #3 on: 22 October 2011, 15:18 »
thankyou for your help, someone else on another site has alos said it may be a pcv problem, any idea how much to fix????
Offline Saint Steve
« Reply #4 on: 23 October 2011, 18:28 »
Defo  faulty PVC.£35 part, and half hour to replace tops.
Offline Saint Steve
« Reply #5 on: 23 October 2011, 18:28 »
Offline vw spur
« Reply #6 on: 23 October 2011, 19:03 »
wow, that sounds like a cheap fix, does it require specialist tools??? i dont have many tools, so might just buy the part and get a garage to put it in if its only 30 mins labour
Offline bacillus
« Reply #7 on: 23 October 2011, 19:32 »
Very easy to replace yourself...
Without traction power is nothing!
Offline vw spur
« Reply #8 on: 23 October 2011, 19:48 »
any idea what tools are required pleaes??
Offline bacillus
« Reply #9 on: 23 October 2011, 20:17 »
This pdf is for installing the bsh pcv revamp but it tells you what you need to do to remove your existing pcv.
http://www.bshspeedshop.com/bshstore/instructions/fsi_pcv.pdf
