Author Topic: thermostat on the mk3 AGG engine  (Read 5268 times)
Offline sharki786
  • GOT BOOST??
« on: 18 October 2011, 10:58 »
ive searched but still seem confued. need to change the thermostat on my AGG, is it located under the water pump? or under the PAS pump? also my car today took over 10 mins to get to the 1st minimum line and when the temps fully on the half mark the top pipe is hot and bottom is warm-hot (always been like this) will changing the thermostat sort this out? also how do i get to it? need to know sa i will attemp this today and need to be sure dont want any hickups.
thanks all
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline justalex81
Re: thermostat on the mk3 AGG engine
« Reply #1 on: 18 October 2011, 11:11 »
don't know exactly where the thermostat is located but i'm pretty sure that the thermostat is your problem and replacing it will solve the problem
Offline sharki786
  • GOT BOOST??
Thermostat on my mk3 AGG engine
« Reply #2 on: 18 October 2011, 11:12 »
P.s it has the common symptoms of raising to 90 in traffic and then drops to 70 when i start driving.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 18 October 2011, 11:13 »
Cheers alex. Did you read my last reply to this post? Of the temp on 90 when in traffic and then drops to 70 when on the move.
*****MK4 GTI T*****
« Reply #4 on: 18 October 2011, 11:37 »
Could be an air lock.
Offline javalin
« Reply #5 on: 18 October 2011, 11:43 »
thermostat is below the water pump and behind the PAS pump.  You don't need to disconnect the PAS to change the t-stat, just move some pipes out of the way.
see dans guide - http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/coolingmaint/index.htm
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 18 October 2011, 13:04 »
cheers javalin. should i get the parts from TPS? i can get a febi t-stat for £6.30 +vat
also what mix of water and coolant should i use? 50/50, or 60 water & 40 coolant?
going to get t-stat, G12 coolant (this any good for my AGG), expansion bottle & both belts
*****MK4 GTI T*****
Offline javalin
« Reply #7 on: 18 October 2011, 13:10 »
get a VW stat or www.vwspares.com
50/50 coolant and water, and its the G12 I believe.   Get geninue stuff - not generic!!
You don't need to change the expansion tank unless you particularly want to, or its particularly gunked up.
J
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 18 October 2011, 16:02 »
hi mate,
yes its all brown so thats why i want to change it. but as cars running fine atm i might just leave it for now, going to get parts from TPS (they genuine parts)
thanks for you help mate and everyone else who helped out.
Cheers people
*****MK4 GTI T*****
Offline harlemex
« Reply #9 on: 18 October 2011, 22:30 »
If its all brown, you might want to invest in some rad flush aswell.  :shocked:
