Author Topic: Calling all Plumbers!  (Read 4027 times)
Offline Seanl
« on: 18 October 2011, 08:44 »
I bled my radiators yesterday as the tops were only getting warm but bottom was nice and toasty. Problem is, I did it with the heating switched on as thats how I thought it was done. The pump started squealing in my combi, and now the heating and hot water doesnt work at all. I switched everything off, and bled it all again, then turned it back on, but as soon as I manually turn the heating on, or turn a hot water tap on, the pump sqeals for a second, and the heater ignites, but then switches itself back off. Boiler is a worcester 28cdi, and was serviced annually until I moved in 3 years ago  :lipsrsealed:
Any help very much appreciated, as I cant find a definative answer online. Cheers.
Offline Toby
  • Car - less
Re: Calling all Plumbers!
« Reply #1 on: 18 October 2011, 09:08 »
Im sure alex will be along shortley, im a plumber but i know nothing about boilers
Currently down under
Offline Seanl
« Reply #2 on: 18 October 2011, 09:14 »
Cheers bud!
Offline luke
  • When in doubt, whip it out!
« Reply #3 on: 18 October 2011, 09:23 »
pretty useless plumber then  :grin: :grin:
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline justalex81
« Reply #4 on: 18 October 2011, 09:31 »
where is your boiler located? i assume it's upstairs or in the loft.
when you bleed a pressurised system you must top the pressure up at the boiler via the filling loop. what you've done is fill the radiators with the water that was in the boiler and the pump has run dry.
First thing to do is re pressurise the system. The pressure should be approx 1bar or 14.4psi when the system is cold.
How long did you let the pump scream for before you switched it off?
« Last Edit: 18 October 2011, 09:35 by justalex81 »
Offline Seanl
« Reply #5 on: 18 October 2011, 09:45 »
Ah cheers. Yeah boiler is in the airing cupboard in the upstairs landing. How do I re pressurise the system? There is no pressure indicated on the boiler, the dial and red indicator needle is at just over 1bar atm but the pressure needle is at 0. The pump must have run for about half an hour before I noticed it. :embarassed: Hope I've not buggered that!
Thanks Alex, appreciate it.  :smiley:
Offline Toby
  • Car - less
« Reply #6 on: 18 October 2011, 10:45 »
Alex to the rescue  :grin:
Underneath the boiler where all the pipes are, depending on your boiler there should be a 15mm mains freed and maybe a silver flexible connector with a knob on, turn that till the preasure reg is around 1.5 bar the. Bleed the rads again just to get rid of any air, then check the gauge, as for yhe noise iv no idea! :smug:
Luke ........ f**k off  :grin:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #7 on: 18 October 2011, 10:51 »
toby lad  :wink:
my radiater in the conservatrie wont work ive bled it ,soon as a turn the key to bleed water comes out  :undecided:
all other rads are fine
Offline justalex81
« Reply #8 on: 18 October 2011, 11:09 »
toby calm down pressure when cold doesn't need to be more than 1 bar!
If the pump ran dry for half an hour there's a good chance you've burnt it out or very nearly.
daz veedub turn all the trv's off to all radiators in the house and leave conservatory open. does it get hot then? if so then it's a case of balancing all the valves on your rads so that the water is pushed through the conservatory radiator. if all the rads nearest the boiler have the valves wide open then the water will take the path of least resistance and just circulate around those. You need to shut the trv's down enough to still enable the radiators to get hot but also enough to force the water around the whole system.
Offline daz veedub
« Reply #9 on: 18 October 2011, 11:14 »
cheers mate
what are TRV,S tho lol
