Author Topic: underside rusting  (Read 2459 times)
Offline Len
Re: underside rusting
« Reply #10 on: 18 October 2011, 13:37 »
And again you are too stupid to understand.
IF it was only surface rust as you said it would never make it onto an advisory list!
Therefore it must be more than surface rust and must be dealt with more firmly than a wire brush!
I would also add that wire brushing rust without then using something like kurust to chemically stop the rust will also be wrong!
www.sas.org.uk
www.the-ace.org.uk
Offline VR6_Wherry
« Reply #11 on: 18 October 2011, 13:58 »
Come on now ladies... :grin: :grin:
Offline AudiA8Quattro
« Reply #12 on: 19 October 2011, 14:47 »
Not really, testers put all sorts of things on advisory sheets, even oil leaks and other non MOT items  :lipsrsealed:
Offline Len
« Reply #13 on: 19 October 2011, 15:25 »
You know some cr@p testers then Corin! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
« Reply #14 on: 19 October 2011, 16:21 »
i've had an advisory for underside rust before, so did the the old horsebox (class 7 mot)
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #15 on: 19 October 2011, 16:50 »
Not at all Len. Its standard practice to put any mechanical defects or leaks on the advisory list.
It shows VOSA that the tester is paying attention  :wink:
