Author Topic: underside rusting  (Read 2456 times)
Offline birch
underside rusting
« on: 18 October 2011, 07:49 »
my 1993 8v got a couple of comments on the mot advisory about rust starting underneath the car. 'corrosion around rubber grommets in the floor' ive tried a couple of rust stopping products in the past with little success, can anyone tell me the best method and product to try and stop or at least slow down the corrosion. thanks.
Offline Seanl
Re: underside rusting
« Reply #1 on: 18 October 2011, 08:55 »
Cut it out, and weld in new. You will only slow the spreading down by treating it, and I wont make any difference to the areas that are already affected. Shouldnt cost massive amounts and you will just keep spending money on kurust or the like, paint, underseal etc etc anyway.
« Reply #2 on: 18 October 2011, 09:02 »
If it is only surface rust, wire brush back and treat with underseal. :smiley:
Offline Len
« Reply #3 on: 18 October 2011, 10:02 »
It wont be surface rust for an MOT advisory! :rolleyes:
Those grommet things are an absolute pain!
As Seanl says get it cut out and welded is best solution and a good underseal.
www.sas.org.uk
www.the-ace.org.uk
« Reply #4 on: 18 October 2011, 10:21 »
If it was major rust it would have failed  :rolleyes:
It says rust starting underneath the car so if caught in time might not need plating.
Offline AudiA8Quattro
« Reply #5 on: 18 October 2011, 11:10 »
Stop flirting you two  :grin:
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #6 on: 18 October 2011, 11:59 »
Will need to cut it out to do it right. Rust is like a cancer and will spread if not dealt with. Those floor gromets are easy to sort out.
Offline Len
« Reply #7 on: 18 October 2011, 13:21 »
Try and read what I said numpty!
www.sas.org.uk
www.the-ace.org.uk
« Reply #8 on: 18 October 2011, 13:27 »
I did  :smiley: , and as I said if it was too bad it would have failed the mot so if it is caught in time what is the point of cutting it out, when cleaning it back, treating it and undersealing it would do the job.
My god I never missed you once when you went on holiday  :grin:
Offline Gti_Jamo
« Reply #9 on: 18 October 2011, 13:37 »
I'm sure corrosion will only fail if its within 12 inches of a structural area like suspension mountings, seatbelt mounting etc. Or if its exposed with jagged edges. Those grommets could be a rusty gaping hole and still pass if outside the prescribed areas.
