Author Topic: Freeview Aerial Help.  (Read 2345 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 17 October 2011, 15:12 »
In need of some help here.
I have an LCD TV that has this 'Freeview' built in to it.  I am like a dinosaur when it comes to technology!  Well I have a little aerial that I have plugged into it and it is picking up some channels but I only have to fart and it goes out of signal thus having to alter the aerial again!  The aerial was only £7 so not expecting the best. But on the outside of my house I have one of the old aerials with the co-ax lead cut about 5" off the aerail. Firstly would this aerial be ok with Freeview and secondly would it just be better for me to go and spend £20-30 on a better indoor aerial and if so do I need special one for Freeview?
Offline jonlord321
Re: Freeview Aerial Help.
« Reply #1 on: 17 October 2011, 15:19 »
Hi, I think you need a modern digital aerial, if you have spent £££££s on a decent lcd tv , don't you think it deserves a decent signal, I would get the best you can afford as a tv is only as good as it's signal.
Offline barrym381
« Reply #2 on: 17 October 2011, 15:19 »
use the 1 on top of your house mate
Offline Mikester
  • Civic Type R
« Reply #3 on: 17 October 2011, 15:21 »
The ariel on my roof is probably 15 years old, battered and hanging wonky of the chimney.
When normal analogue TV was still available i could barely get a few freeview channels.
All the adverts were saying you needed fantastic new expensive ariels to get freeview.
When they turned off analogue and boosted the freeview signal i had no issues.
I now get all freeview channels perfectly on my battered old ariel on the roof!
So... Give it a go, got nothing to loose. If it dont work its new ariel time.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #4 on: 17 October 2011, 15:42 »
Thanks guys.
Will go out and get a load of co-ax cable and see how the outside aerial does......Trouble is I am going to need about 50 meters of co-ax!
Offline mcgee9t2
« Reply #5 on: 17 October 2011, 15:52 »
We needed an areal on top of our house. but due to were we live the areal is rediculously big. (The pole to support it is about an inch thich. if not more. and about 8or 9 foot tall )  :grin:
Offline golf newbie
« Reply #6 on: 17 October 2011, 16:15 »
Rod Hull springs to mind in this thread.. :laugh:
Offline Dan n Nic
« Reply #7 on: 17 October 2011, 18:02 »
I'm using the original 1984 aerial that was put on my house when it was built and my freeview signal is better than my sky signal!
Offline tomp
« Reply #8 on: 17 October 2011, 19:48 »
Amongst other things, I design, and my company installs aerial systems both domestic and commercial. (Caravan sites, etc - a site we have just done has 423 caravans running off one aerial)
To receive Freeview signals through your aerial you need a minimum signal of 45db (and not exceeding 75db) and a MER (Marginal Error Rate) over about 22ish. Unless you are right next to the transmitter, you are unlikely to achieve this with an indoor aerial.
If you are on a main transmitter you will get the full Freeview channel line up (about 85 channels) if its a relay transmitter you will only get 18 channels as relays only have three multiplexes. Wether the aerial is horizontally or vertically polarised depends on wether its a relay or main transmitter.
Depending on how far you are from the transmitter and the lie of the land, your old aerial may be ok, without putting a meter on it, its impossible to say what the exact signal its receiving will be. A decision is normally made after checking the signals as to wether a masthead amplifier is required and if so, what value. The aerial meters I have on each of my vans cost about £2500 + VAT each!
Its impossible to accurately say from here wether your existing aerial will give reliable reception as it is, however, as you are picking up some channels on an indoor aerial, I would guess that the signals are pretty good in your area, so you should have better luck with the outdoor aerial, its certainly going to be an improvement. Make sure you use proper connectors when joining cables and waterproof any joins that are outside with self amalgamating tape as if any water gets into the cable, it will end up in your tv. We sell 32 Element high gain aerials designed for digital for about £30 + VAT. Stuff that we use on blocks of flats etc can be 5 to 10 times that price.
50m cable run is pretty far in a domestic situation. Depending on the quality of the coax cable you buy, I would expect to see a loss of around 10db over the length of that cable run.
If you need an amplifier, then Vision stuff is the best.
Hope this helps...
If you need any more advice, let me know...
Offline salsheikh
« Reply #9 on: 17 October 2011, 20:12 »
your a gippo arent you  :laugh:
