Author Topic: Freeview Aerial Help.  (Read 2346 times)
Offline tomp
Re: Freeview Aerial Help.
« Reply #10 on: 17 October 2011, 20:14 »
your a gippo arent you  :laugh:
You got me! Got any scrap?  :grin:
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #11 on: 17 October 2011, 20:41 »
awesome advice tomp :afro:
Offline golf-sib
  • Турботазик
« Reply #12 on: 17 October 2011, 20:51 »
There was me thinking all you do is stick an aerial up and wollah.
If you need a lot of coaxial go wilkinson, the reel will work out cheaper than buying it per meter price, I bought a reel and used it in 3 houses and still have some left over, the thing doesn't end and I payed around £25-30 for it.
Whats the best way to split an antenna so then it runs into different rooms? Aerial is currently on roof and I have power access in loft?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline tomp
« Reply #13 on: 17 October 2011, 21:08 »
Careful with cheap cable, you want foam filled cable preferably CAI approved (Confederation of Aerial Industries). Cheaper air filled cable lets water run down inside it, right into your television if it gets damaged or there's a bad join. For what it costs, and for how often you do it, its well worth paying a little bit extra for decent cable. Cheaper cable normally isn't as well shielded so can let unwanted signals into it. We only use WF100, and we use about 1 km most weeks. (We sell it at 70p per metre so its not really that expensive anyway).
As for splitting the signal, it really depends on the signal strength to begin with, a passive splitter has about 3-4db insertion loss so if the signal strength is good (say above 60db) then just use one of them. If not then you can use a two output masthead amplifier and have two cables from the aerial and a power supply on one of the legs, or if you have a sky box in the main room, just plug the aerial into that then use the RF2 output to another room (bonus with this is that the sky will be combined with the Freeview so you will have an analogue sky pic at the second point - add a digilink and you can control the sky box in the second room), or put a two way powered distribution in the loft, aerial into that and then out of that to the two points.
Really depends on the layout of your house, signal strength and what equipment you already have, there are lots of ways of doing it....
As for just sticking an aerial up and wollah, its a bit more scientific than that (although there are loads and loads of cowboys out there!)
We are the only Confederation of Aerial Industries Approved Systems Installers in North Wales and as a result do systems work for several Local Authorities and the NHS...
« Last Edit: 17 October 2011, 21:12 by tomp »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #14 on: 17 October 2011, 21:16 »
There are some bad signal areas in MK, for the last time I worked there about 8 years back I remember some areas where working of a relay transmitter and had have major issues with the digital transponders, I dont know what updates they have carried out since in thr MK area.
You can always try my other company for advise.. :wink:  http://www.acornaerials.co.uk/
 01455 617233
Offline golf-sib
  • Турботазик
« Reply #15 on: 17 October 2011, 21:18 »
I was thinking of dropping the aerial  into the loft and splitting it 4 ways along the side of the house from there and going:
Living room
Front bedroom
Rear bedroom
Dining room or kitchen
Am I correct in thinking every time I split the cable, the signal drops in the ratio of the split?
1.8T AGU..
R135
  24
Offline tomp
« Reply #16 on: 17 October 2011, 21:28 »
Only if split passively, you just need a 4 way powered distribution amplifier in the loft, something like an SLX4. Aerial plugs into this, then the 4 outputs to your points.
An SLX distribution amplifier actually has a 4db signal gain per output...
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #17 on: 17 October 2011, 22:04 »
http://www.digitaluk.co.uk/postcodechecker/
Pop in your postcode and house number Godzilla.
Then Click on "Check other transmitters at your address" to find out about channels and signal strength.
Then go back to the screen where you enter your postcode, but this time..
Check the box that says "I am in the aerial installation trade"  This will then give you compass bearings to transmitters.
Then you now have the necessary info to point your aerial in the right direction for best signal strength / channels.
« Last Edit: 17 October 2011, 22:07 by The Mighty Elvi »
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #18 on: 17 October 2011, 23:05 »
Thanks mate  :wink:
Mine is coming up as 'Good'  :smiley:
Thanks guys for the replies. Well I have attached new co-ax cable to the aerial which was fun as the aerial is right on top of my house next to the chimney. Due to my house being 118 years old it has the old slate tiles up there which proved much fun to get down when it decided to start pouring down with rain just after finishing the aerial  :grin:  As you can most probably tell.....I don't own a ladder!
Offline tomp
« Reply #19 on: 17 October 2011, 23:57 »
Wouldn't go that far, there are way too many unknowns for this to be 100% accurate, in our local town, there are a choice of two transmitters, a main and a relay. A postcode check will tell you that the signals are good from the main transmitter, however, in reality half the town can't get a signal from it as the line of site is blocked by a castle!!!
The only way to setup an aerial correctly is with a signal analyser and a decent knowledge of the area. There are different error rates that need to checked etc etc.
Having said all that if the signals are good then chances are it will work just by pointing the aerial the same direction as next door, its the marginal areas that are more difficult. Also a DIYer might be happy with occasional digital break up, a paying customer will not...
You could just do this....
