Author Topic: Valve Guide Replacement  (Read 1977 times)
Offline calum91
« on: 16 October 2011, 19:04 »
I own a 2.0 Golf Mk3 16v ABF. Recently started an engine rebuild and when i removed the valves (with some difficulty), bits of the valve guides were scraped off in the process.
Is it possible and relatively easy to replace these?
Cheers.
Re: Valve Guide Replacement
« Reply #1 on: 16 October 2011, 19:42 »
You need a machine shop to press them into the head.
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #4 on: 16 October 2011, 20:45 »
or you need one of these
http://www.ebay.co.uk/itm/7PC-VALVE-SPRING-COMPRESSOR-KIT-/260872499496?pt=UK_Hand_Tools_Equipment&hash=item3cbd367128
That will not work with replacing the guides  :smiley:
Ha ha true i didn't read the op properly i thought it was just valves themselves but still if your gunna do the valves will need one  :smiley:
Offline tshirt2k
  • Been there...Done that...
« Reply #5 on: 16 October 2011, 20:51 »
Machine shops usually charge around £15/guide.
Mk3 ABF 16VT Megasquirt V3
Offline calum91
« Reply #6 on: 17 October 2011, 18:06 »
Wow, 15 quid per valve is expensive, especially since i have 16!
Think it needs done? I was hoping it would be cheaper. I think it was some of the valve guides that was stripped by the collet grooves in the valve.
Offline tweed
« Reply #7 on: 17 October 2011, 19:01 »
got be cheaper to buy a recon head?
don't you know any1 working in the trade?
Offline tshirt2k
« Reply #8 on: 17 October 2011, 21:56 »
But not all valves may need doing. I did exhaust valves only as they are usually the worst ones. Or you could join CGTI (paid member) and go for a shed head at a good price. Thats with a port and polish too.
