Author Topic: Can any one help me With fault code  (Read 1302 times)
Offline ian007miles
« on: 14 October 2011, 12:07 »
Right I just done a fault scan and this fault number came up 18010. It says in the book power suply(b+) terminal 30-low voltage does any one no wot this means
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Dan_GTi8v
Re: Can any one help me With fault code
« Reply #1 on: 14 October 2011, 15:25 »
Quote from: rosstech wiki
8010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
Possible Causes
Cables on the Battery were removed
Battery weak (voltage)
Generator Disfunction
Possible Solutions
Check Battery Cables
Check/Replace Battery
Check/Replace Generator
Special Notes
If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
Terminal 30 means unswitched battery power that is supplied even when the ignition is off. This is not referring to any physical terminal numbered 30.
Offline ian007miles
« Reply #2 on: 14 October 2011, 15:33 »
Could it be that I took the battery off yesterday ??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 14 October 2011, 17:26 »
yep for defo
jamie16v
« Reply #4 on: 14 October 2011, 18:31 »
yep for defo
+1,
just clear the code and forget!
Offline ian007miles
« Reply #5 on: 14 October 2011, 21:51 »
Ok thanx for the replys
