Author Topic: 1.8 turbo conversion  (Read 24919 times)
Offline Dan_GTi8v
Re: 1.8 turbo conversion
« Reply #30 on: 17 October 2011, 17:41 »
1.8t mk2?  :evil:
Offline stainesy
« Reply #31 on: 17 October 2011, 17:52 »
1.8t mk2?  :evil:
Could well be. My plan is to get one abd strip it down to shell then start from scratch. May even swap my mk3 for a mk2 if anybody fancied my car.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #32 on: 17 October 2011, 20:06 »
1.8t mk2?  :evil:
That is one stunning MK3 Golf you have as well bud. Full leather, coilovers, full s/s VR exhaust, Vento front end......Soooo many mods, this car has to be seen!
Offline stainesy
« Reply #33 on: 17 October 2011, 20:18 »
1.8t mk2?  :evil:
cheers dude. not full ss system though. sebring vr6 cat back.
Offline murraymint
« Reply #34 on: 13 November 2011, 18:12 »
this is just my list, I'll look over it in a bit as I'm in the middle of cooking dinner atm  :grin: Obviously some things are up to you and the code can be any transverse 1.8t (as opposed to longitudinal fitted ones like those in the U.S)
*Cable to hydro clutch parts (master cylinder, slave cylinder, and fluid lines)
*Engine and Gearbox brackets
*Engine and Gearbox mounts
*Engine AUM
*Gearbox 02a
*Intercooler
*Boost pipes
*VR Clutch
*ABF Flywheel
*Downpipe from QPeng (ask Kells about his though, same price and better quality)
*Sports cat (for no messing about at MOT)
*MK4 PAS Pulley
*SAI block off plate
*Forge TIP
*Forge 007 recirculating diverter valve
*modified loom (give rubjonny a pm or I think topher knows someone who can do it as well)
*ECU immob defeated and 2nd lambda mapped out (Topher did this for me along with a stage 1 map)
*16v starter motor
I'll add to it as I remember anything else :)
There will be many things you forget about or wont know you need until you come to it. I started from an 8v GTi, ideally you wanna start with a 16v as a lot of the work will be done for you.
what are you starting with? anything under a GTi would need other stuff as well such as bigger brakes etc
is there a complete list anywere on here?
josh
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #35 on: 13 November 2011, 19:09 »
theirs never gonna be a complete list as it depends on each car/ engine code used etc and how far you wanna go.. those are the basics tho
also factor in the exhaust as you really do need a 2.5" bore system (Jetex) and these are pretty expensive unless you already have it
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline murraymint
« Reply #36 on: 13 November 2011, 22:56 »
okay then cheers, wheres the best place to get the jetex system from?
josh
Offline Dan_GTi8v
« Reply #37 on: 14 November 2011, 00:23 »
www.ebay.co.uk :P
if you are gonna be getting parts together over time it could be worth checking every now and then for a 2nd hand system on ebay, wont be rusted as there stainless so imo 2nd hand is just as good as new as long as the tail pipes are not scratched or dented
Offline murraymint
« Reply #38 on: 14 November 2011, 07:27 »
Thanks Wayne seems a bit obvious now lol.
www.ebay.co.uk :P
Yh Im planning to start buying stuff for it just after Christmas. Yh will have a look on ebay. Love grabbing a bargin lol
josh
Offline F17BAD
« Reply #39 on: 14 November 2011, 17:55 »
mate i found the cheapest place for the Jetex is Venom motorsport, bought mine here and one for a MK4 here too. Im also getting the one for my MK2 20VT conversion at Venom too..  both times iv had the others they arrived in a couple of days direct from Jetex factory
