Author Topic: Recieved depo's + hid, would just like clarification with pics  (Read 5325 times)
Offline Chris#101
How do just recieved both my depos and 10,000k h7 HID kit :cool:
Sounds a bit gash I know but Just spent a fair bit on these and dont want to break either so best ask ehh  :embarassed:
Just want to clarify realy that Iv got it set up right, as it seems weird that theres no power needed unless its linked somewhere in the actual headlight that then connects to the original lighting plugs in the cars loom!? and Dont even get me started on the instructions  :rolleyes:
So I presume these spade connectors go in here!? not sure what that other wire and connector is for (can someone point me in the right direction!?)
with me thinking this is the finished article!?
thanks guys and girls
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline dom
  • Back in a Mk4
Re: Recieved depo's + hid, would just like clarification with pics
« Reply #1 on: 12 October 2011, 14:37 »
That looks right to me, they are powered in the same was as all other bulbs in the unit, only you have the ballast to ensure the current is consistent.
The white cable is for the motor to adjust the beam angle, before you fit the lights make sure you change them to RHD otherwise you'll blind everyone!
Offline km
« Reply #2 on: 12 October 2011, 14:40 »
all connected correctly and the other wire connects to the headlamp adjusters, that look like the following.
Offline Horney
« Reply #3 on: 12 October 2011, 14:47 »
And take em off for your MOT. They're a fail from January 1st.
Nick
Offline Chris#101
« Reply #4 on: 12 October 2011, 14:51 »
Starting to love this forum more and more, Wasnt expecting answers that quick  :shocked:
No excuse then I guess, best get my wax coat and bare the rain and fit these :cool:
Will get pictures fitted later!
thanks again guys
« Reply #5 on: 12 October 2011, 15:16 »
As Nick said HID's will fail the mot from January 1st  :smiley:
Offline harlemex
« Reply #6 on: 12 October 2011, 15:20 »
As Nick and Wayne said, will fail mot from january.  :tongue:
Offline Chris#101
« Reply #7 on: 12 October 2011, 15:21 »
thats fine means and ways round that!!
Next question! how the hell do you take out headlight adjusters from oem lights to put into the depos!? :huh:
« Reply #8 on: 12 October 2011, 15:27 »
Worth remembering that you could still fail a roadside check. :smiley:
Offline km
« Reply #9 on: 12 October 2011, 15:33 »
just twist them from what i remember?
