Author Topic: Recieved depo's + hid, would just like clarification with pics  (Read 5332 times)
Offline Chris#101
Re: Recieved depo's + hid, would just like clarification with pics
« Reply #10 on: 12 October 2011, 15:53 »
just twist them from what i remember?
10 points to you sir :wink:
Next question Where does the foglight spade go!? and what goes to this spade connector box? has 2 slots to be filled :undecided:
cheers
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Ant1981
  • Feed me, prod me
« Reply #11 on: 12 October 2011, 16:42 »
thats fine means and ways round that!!
Worth remembering that you could still fail a roadside check. :smiley:
The light clusters have a projector unit, so if he fits them there, he should be fine, however, he will still be one of those inconsiderate 'I want brighter headlights that make your retinas hurt and iris shut down causing a danger to other people around as you can't see now' drivers.
'09 Kawasaki Ninja ZX-6R
Offline Chris#101
« Reply #12 on: 12 October 2011, 16:46 »
Rightt latest problem!!
Cant get either high beams to work!?
How ever
foglights come on with command from 'highbeam stalk possition' in cabin
Offline dom
  • Back in a Mk4
« Reply #13 on: 12 October 2011, 17:07 »
When you upgrade to the DEPO headlights you need 4xH7 bulbs (one for the dipped & main beam in each unit), standard headlights have 2xH7 and 2xH1.
The block that your holding in the last picture is for your main beam bulb.
There should be a yellow(?) wire with a connector floating around somewhere in the unit, this is for the fog light wire to connect to. The black wire is already connected to the fog lighter holder.
Hope that makes sense.
Offline dom
  • Back in a Mk4
« Reply #14 on: 12 October 2011, 17:09 »
Infact I've taken another look at your pic, the yellow wire is connected to a H1 bulb in the main beam unit, unplug this and connect it to the fog light. Find another H7 bulb to put in our main beam unit and plug that connector block into it = job done :wink:
A picture says a thousand words:
« Last Edit: 12 October 2011, 17:12 by dom069 »
Offline Chris#101
« Reply #15 on: 12 October 2011, 17:27 »
You sir are the freaaking man  :cool: :cool:
I now have high beams :laugh:
How ever I dont have fogs :undecided: do all of the Gtis come with front foglights as standard??
Offline dom
  • Back in a Mk4
« Reply #16 on: 12 October 2011, 17:47 »
Not sure, I would have thought so :undecided:
Did your standard headlights have fogs built into them? Another way to check to to see if your switch pulls out once or twice when the lights are on, once is rear fogs, twice is front :wink:
Offline Chris#101
« Reply #17 on: 12 October 2011, 17:56 »
Hmm strange one, My oem lights had front fogs and bulbs in them but I never tried to see if they actually worked,,, schoolboy error  :rolleyes:
another question will it be safe to run 100w high beam bulbs in the depo with out melting anything etc!?
 :smiley:
Offline dom
  • Back in a Mk4
« Reply #18 on: 12 October 2011, 18:19 »
 :smiley:
100w aren't legal, stick with 50w :wink:
Offline bricey
  • One of a few with a PROPER engine
« Reply #19 on: 12 October 2011, 18:36 »
does all wat has been said apply to all depo lights i was going to get a set at the end of the month but looks abit like a
train crash :huh:
DOLPHIN TRAINER
