Author Topic: Temp sender  (Read 1216 times)
Offline Chris_D
  • www.hijackbristol.co.uk
Temp sender
« on: 26 April 2005, 22:37 »
Yesterday i changed the plastic housing on the front of the head with the hoses leading to it, obviously i had to put the temp sender on to the new one and the other sender (what is that one for?) i can hear a slight leak from around the blue one(that is the temperature one right?) when i squeeze the hose, it's not leaking water but can hear air coming from it, should these be sealed and if so how?
Chris
Re: Temp sender
« Reply #1 on: 27 April 2005, 08:35 »
There should a rubber o'ring between the sender and the housing.  The blue sender goes to the ECU and the one underneath (black?) with a red/yellow wire going to it is for the dash gauge.
Offline Chris_D
Re: Temp sender
« Reply #2 on: 28 April 2005, 18:17 »
i have 2 on the top? are they both for temperature?
Where i can i get new ones from and how much anyone?
Offline wellfan
Re: Temp sender
« Reply #3 on: 28 April 2005, 20:49 »
'O'rings for the temperature senders are available from a VW dealer, I recently bought one, cost about £1.00 each, absolute rip off for a rubber band.
