Author Topic: Exterior Lights Stay On After Locking  (Read 9246 times)
Offline KennyGTI
« on: 10 October 2011, 20:13 »
Noticed a Mk5 GTI the other night when the guy got out and locked the car his lights stayed on for 20 to 30 secs? My lights come on when I unlock at night but would like if it done the same when locking it. Any ideas how to? :huh:
APR Stage 2+
Offline ajmoir36
Re: Exterior Lights Stay On After Locking
« Reply #1 on: 10 October 2011, 20:44 »
Pull the flash lights stalk to keep them on and the switch must be in the (auto position i think).  I would prefer it if I could code it to make it the same as the mk5, I thought I have found it as there is a manual/auto for the lights, just haven't been brave enough to code it to see what it does.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Mr Smooth
« Reply #2 on: 10 October 2011, 20:48 »
This is called coming/leaving home. On the MK6 you need to flash your high beams once before you open the drivers door,and should remain switched on for the amount of seconds you set it in the MFD after you lock the car.
MK6 GTi DSG Tornado Red
Xenons,Sunroof,PDC Front & Rear,RCD510,LED Rear Tail Lights.
Offline KennyGTI
« Reply #3 on: 10 October 2011, 20:58 »
So you need to flash before u get out the car? Will look as if, hey everyone look over here, my lights stay on after I get out the car! Would rather you could just make them stay on, hopefully someone knows how to via vagcom?
APR Stage 2+
Jimmymature
« Reply #4 on: 10 October 2011, 21:05 »
Yes you have to flash before you turn the ignition off, I too would love to have it auto but never been able to find anyone who can help.
Jim
Offline mike.
« Reply #5 on: 10 October 2011, 21:33 »
You need to set the coding in the BCM as below, for automatic operation.
BIT2 set to 0 means it works like the MK5
BIT0 sets the timer to start from ignition off or door opening
« Last Edit: 10 October 2011, 21:35 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Jimmymature
« Reply #6 on: 10 October 2011, 21:46 »
Mike, you're a star. I just need to find someone local who will code it for me  :sad:
Jim
Offline p3asa
« Reply #7 on: 10 October 2011, 22:02 »
Jim
I'm sure you only have to flash before the door is open rather than the ignition off or at least that is how mine is set up.
For the times I forget to flash the lights I just lock then unlock the car and the lights stay on for a period of time.
The doors then automatically lock again after 30 seconds   :smiley:
Offline ajmoir36
« Reply #8 on: 10 October 2011, 22:09 »
Thats the bits I seen, it did look obvious, will have to fix mine now then too.
Offline KennyGTI
« Reply #9 on: 11 October 2011, 08:25 »
Will get the VAG Com out tonight then!  :evil:
APR Stage 2+
