Author Topic: peugeot 206 torque settings (fao THOM one last request)  (Read 1919 times)
Offline justalex81
As above for a 2004 1.4 8v engine. yes i know it's french and should be scrapped but it's my girlfriends and we entrusted a cambelt change to a recommended (friend of a friend) mobile mechanic and he timed it up wrong and has bent all the valves. So, i'm fixing it myself and need torque settings for all things relevant to removing the head and refitting. If anyone owns a haynes manual that could sort me out that info then i'd be really grateful.
Cheers guys
« Last Edit: 10 October 2011, 18:58 by justalex81 »
Offline AudiA8Quattro
Re: peugeot 206 torque settings
« Reply #1 on: 09 October 2011, 16:11 »
I do have autodata that covers most stuff if you have the engine code.
However, if you're going to take on a big job, i would suggest buying a manual.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 09 October 2011, 17:19 »
-----------------NM----------lbf ft
Stage 1......... 20------------15
Stage 2..........Angle tighten a further 120 degrees
Stage 3..........Angle tighten a further 120 degrees
Thom
« Last Edit: 09 October 2011, 17:21 by thom89 »
Offline luke
  • When in doubt, whip it out!
« Reply #3 on: 09 October 2011, 17:22 »
if he done it wrong, send it back to him to fix it for free
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline DOA
« Reply #4 on: 09 October 2011, 17:26 »
Your sure he timed it up wrong? Had something similar on my old 106Gti, turned out the crankshaft woodruff key was fubar and had sheared prior to me taking the cams out to re-build the lifters. I put the cams back in without paying heed to what I thought was a visual illusion but turned out to be the crank pulley turning independant to the crank whilst I was turning it over to get the timing right and hey presto, once back together it bent 8 valves  :undecided:. Worth checking anyway whilst your doing the work  :smiley:. If that looks fine I would be asking for the labour money back at the very least!
Offline bodga
  • F reg GTI 16v
Offline justalex81
« Reply #6 on: 09 October 2011, 18:34 »
cheers for the responses.
basically he timed it up approx 60 degrees out and turned it over before realising the mark on the crankshaft pulley means nothing in relation to the timing of the engine. he then rang peugeot who told him how to do it correctly (lock the flywheel using a punch through a hole in the bellhousing.
by then the damage was done. at the time i didn't realise what he'd done and he told me that he be back the following day to sort it. the next day i got a text to say the keys were on top of the wheel and there was a business card of a garage who would fix it. i can no longer get in contact with him as he won't answer his phone. He was a friend of my gf's auntie and he was recommended.
Even though i paid cash and there is no paperwork i have a conversation on facebook between him and my missus confirming the work to be done and how much it was going to cost. i can cross reference that with a bank statement and cctv of him turning up and doing the work. thinking about small claims court and inland revenue to really hurt him.
basically i'm doing the work with the help of a friend who used to be a mechanic. we have all the tools and new parts and i've already stripped down the engine. just need torque settings for anything that should be tightened up to exact specifications.
engine has only done 60k.
« Reply #7 on: 09 October 2011, 18:37 »
What is the engine code?
Offline Thom89
« Reply #8 on: 09 October 2011, 18:44 »
Most likely TU
Thom
Offline justalex81
« Reply #9 on: 09 October 2011, 18:51 »
yeah was just about to say TU.
if anyone knows the correct gap for the tappets also that would be great.
cheers
