Author Topic: Some Advice / Help  (Read 1605 times)
Offline CMD
Some Advice / Help
« on: 03 October 2011, 18:33 »
After buying my first golf MK4 GTI Turbo 2 weeks ago I am now ready to start sorting out a few common/not so common problem's so sorry if i ask for to much Help..
Problem 1.. Side Light bulb Blown, now sorted after taking off the front bumper I also changed the the Orange indicator bulbs for some Chrome bulbs.
Sorted
Problem 2  On replacing headlamp and bumper I checked all was working (Daylight) . But i noticed when i used the car to go to work today the headlight adjust (up/down) was not working on the headlight (passenger side)i replaced the side light bulb in.. Have i done something wrong when removing the headlight from the Car.
Problem 3.. I have all the keys with the car (3 keys plus Master) The remote does not open or close the car. I use one of the spare keys to open the drivers door and to start the car up. Now if i open the drivers door and dont put the key into the ignition and turn on the ignition within 30 or so seconds the Alarm goes off.
Problem 4 I can only open the boot using the key (car open or closed)
Problem 5 I remember reading about this at some point, can someone link me to this .. The car's temp will only go to about 75 and not 90 even on a long run Help with this please.
Advise now please.. Can the coil packs be changed on these 1.8t engines so i can do away with the big bolt square box type bolt down coil pack's.
Problem 5.. The Puddle light on drivers door and roof lights don't come on when i open the drivers door but do on the passenger door.. I have changed the bulb in the puddle light and all the roof lights are fine and work when switched on/off..
Any links to these problems will help saves me asking all the time.
Thanks All
Offline Rhyso
Re: Some Advice / Help
« Reply #1 on: 03 October 2011, 18:37 »
How do Colin  :wink:
Problem 4 - boot switch has most likely bit the dust
Problem 5 is either the thermostat or temp sender
Problem 6 is most likely the door module and is approx £100 from VW  :sad:
Coilpacks - ring VW with your reg number and see if your call is eligible for new ones under the recall.  The same applies to your A4  :wink:  But the bolt down ones are the best ones to have  :smiley:
Let me know when you want it scanned and we'll point you in the right direction :afro:
Offline james2
  • No scammers please.
« Reply #2 on: 03 October 2011, 18:41 »
Problem 6.. The Puddle light on drivers door : its the micro switch on lock of door mine did this.You can get a new one or use my cheap fix  :lipsrsealed: .get a screw driver and hammer .Put the screw driver in a screw head that holds the door lock in and tap it with hammer until light comes on . :wink:
Problem 5: thermostat
« Last Edit: 03 October 2011, 18:45 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline CMD
« Reply #3 on: 03 October 2011, 18:54 »
My man Rhyso. I need to do most of the work on the Golf myself as having blown the budget on this car, so Links to DIY will help in a big way. I will get the parts from TPS.
Offline CMD
« Reply #4 on: 03 October 2011, 18:57 »
Cheers James, I will consider your method
Offline Rhyso
« Reply #5 on: 03 October 2011, 18:58 »
Thermostat
http://www.golfgtiforum.co.uk/index.php?topic=101783.0
Lets get it scanned to confirm the other faults before you part with your hard earned  :wink:
Re-reading problem 3 I might be able to recode your keys as its possible they've lost sync with the car
Offline CMD
« Reply #6 on: 03 October 2011, 19:01 »
Thermostat
Your a star Rhyso.. I will have to write out a BIG IOU.
