Author Topic: MK5 GTI with DSG  (Read 3997 times)
Offline X4MGS
  • VAG Parts SNOB!!!
MK5 GTI with DSG
« on: 02 October 2011, 17:07 »
Hi Guys... Don't normally pop this high up the golf numbers as I'm a true MK2 Lover...
But I'm looking at buying a 2006 Mk5 GTI with a DSG box with 72K next weekend...
Do you have any tips as to what to look for when testing one...
Do they have an Achilles Heel??? How reliable is the DSG??
MK2's it's rust, rust & rust... :laugh:
Thanks Guys.... :grin:
For More Info Click To See;
Offline tech1889
  • Mk2 GTI FTW !!
Re: MK5 GTI with DSG
« Reply #1 on: 02 October 2011, 17:37 »
my car has DSG with 136k and no problems whatsoever  :wink:
Good all round car just check like anything else if it sounds dodgey ask them to fix it  :grin:
Offline Rhyso
« Reply #2 on: 02 October 2011, 18:04 »
If its clunky going into gear then it could be that it needs a service or the mechatronics unit is failing
Give it a good proper drive and make sure it moves up and down the box smoothly.  If the unit is failing it tends to jump out of gear i.e from 6th to like 3rd  :shocked:
Ask the owner if it has been serviced (think VW recommends every 40K??) and if the mechantronics unit has been replaced
If you get favourable answers to both then enjoy  :smiley: It's a cracking bit of kit and launch control is excellent  :evil:
Offline maxload
  • ED30 / NO.1819
« Reply #3 on: 02 October 2011, 18:05 »
As above. Also i think it's worth asking when the last time the dsg box had a service and weather the mechatronic control module has been replaced under waranty. Other than that all the usual stuff.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 02 October 2011, 18:32 »
mechatronic control module has been replaced under warranty....
Do I take it that these are prone to failure then? or is it a regular serviceable unit?
Thanks for the replies!!
Offline Rhyso
« Reply #5 on: 02 October 2011, 18:35 »
Prone to failure  :sad:  and they are the thick end of £1000..........
Later units seem to be more reliable  :smiley:
Offline Phil1980
« Reply #6 on: 02 October 2011, 21:13 »
The same as Mk5's  :smiley:
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 02 October 2011, 21:24 »
Rust on a 5 year old car I hope not....
My 20 year old cars I expect some...
Offline Jimp
« Reply #8 on: 02 October 2011, 22:05 »
Check the top of the front arch for bubbling as sometimes rust can pop up there. I have a 2006 and it hasn't happened to me, seems more common on 2005 models.
Not low enough mk5
Not on the road enough mk3
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #9 on: 03 October 2011, 22:42 »
i think the mechatronic unit is more like £2200 fitted  :shocked:
