Author Topic: Steering wheel off centre  (Read 3022 times)
Offline Kus
« on: 30 September 2011, 00:04 »
So to go in a straight lane I have to turn the wheel a few cm to the right. Basically it's off centre what could be causing this? Its really pissin me off now so help will be appreciated!
Re: Steering wheel off centre
« Reply #1 on: 30 September 2011, 00:06 »
You could remove the steering wheel and move it around by a spline or get the tracking reset and they should center the steering wheel.
Offline Kus
« Reply #2 on: 30 September 2011, 00:12 »
I'll get it tracked then I was thinking that might be the problem but wasn't sure
« Reply #3 on: 30 September 2011, 00:15 »
I suspect in the past someone has had it tracked without the steering wheel being locked in the straight ahead postion.
paul james
« Reply #4 on: 30 September 2011, 08:18 »
yes mate re-aline the wheel' get a flat head screwdriver about 6inch long turn the wheel 180 degrees to left, there'll be a small hole in the back insert the screwdriver pointing up' as far in as it will go then prise down & it will pop off! then turn it 180 right & do the same.. can be a bit tricky  :undecided: but i got a small mirror got the reflection of the small hole & could see the metal clip that i was prising off made it alot easier. :smiley: then just a case of removing the spline bolt & sitting the wheel back on in the right position.. but be careful of the air bag!! theres no need to remove the wires, i just sat it on the wheel being very careful  :shocked: disconnect the batt if it makes u feel btr. hope this helps! :wink:
Offline houston
« Reply #5 on: 30 September 2011, 11:00 »
seriously? thought you would have had to remove the airbag and steering column nut, have you any pics?
« Reply #6 on: 30 September 2011, 11:02 »
You do, he has not worded it very well.
paul james
« Reply #7 on: 30 September 2011, 14:22 »
i did'nt remove the airbag no need.. if ur not clumbsy enough to drop it & tug the wire out its fine but disconnect the battery to be on the safe side..
« Reply #8 on: 30 September 2011, 15:38 »
Yes but you still need to remove the nut holding the steering wheel on and then move it.  :smiley:
paul james
« Reply #9 on: 30 September 2011, 17:01 »
yes obviously' spline bolt i mentioned earlier..  :rolleyes:
