Author Topic: removing front strut  (Read 2230 times)
Offline dam088888
« on: 27 September 2011, 16:55 »
Hi all going to remove and replace both front struts tomorrow. If I remove the bottom nut on leg first and free it all then do the top one by putting Allen key in top and I got a ring spanner to undo nut will it fall out in one or do I still need to use spring compressers as I ant got none. Just asking as the new ones I got if you take new nut off top of strut the whole tip comes off and you can get to spring
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline andc1
Re: removing front strut
« Reply #1 on: 27 September 2011, 17:00 »
Spring is compressed in, to remove the spring from the strut you will need a clamp
Offline dam088888
« Reply #2 on: 27 September 2011, 17:04 »
Sorry might not of been clear basically I want to remove the whole strut or leg whatever you call it can I do this with out spring compressors
Offline dam088888
« Reply #3 on: 27 September 2011, 17:16 »
Ignore me lads being thick as when you remove the nut on top in engine bay get leg off there is the other nut that golfs top mount :undecided: on sorry for stupid post
« Reply #4 on: 27 September 2011, 20:49 »
Yes.
Correct you will need spring compresssors to remove the 2nd nut.
Offline dam088888
« Reply #5 on: 27 September 2011, 21:37 »
Yes that's cool wayne cos got new leg with spring in all ready
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« Reply #6 on: 28 September 2011, 11:57 »
Yes.
all i do to remove the second nut is put the strut on the floor put 1 foot on the spring and loosen the nut there isnt much compressor there  :wink:.
Offline houston
« Reply #7 on: 28 September 2011, 12:40 »
Yes.
you mad? terrible advice to give, what if his struts siezed and the spring is under a lot higher compression! for the sake of a few quid for a set of clamps i know what id rather do
Offline dam088888
« Reply #8 on: 28 September 2011, 16:06 »
All done and what a mission was all easy but could not get track rod nut off then when I undone it a bit it would not go back on had to grind nut off then put a new one on and that wad both sides all done now tho so all good  :cool:
« Reply #9 on: 29 September 2011, 00:07 »
Madness  :shocked: I have seen a spring let go, not very nice at all.
