Author Topic: 15mm spacer / adaptor trouble  (Read 2058 times)
Offline magsmagsmags
  • Mk4 Golf GTI 1.8T (AUM)
« on: 26 September 2011, 20:51 »
Has anyone had an issues using these?
I fitted some 5x100 - 5x112 adaptors today
Done all the bolts up as tight as can be, went for a drive and after a couple of miles i noticed some serious vibrations so pulled over and all my front wheel nuts were incredibly loose.
I have 15mm on the front, 20 rear. rears were fine. I'm guessing the bolts are too long for front, so when they appear to be tight, they're not?
If this has happened to anyone before, do you know what size bolts i might need?
~Mags~
Re: 15mm spacer / adaptor trouble
« Reply #1 on: 26 September 2011, 21:03 »
Sounds like they may be bottoming out, take a wheel off and see how much thread is showing.
Only other thing is are they the correct taper / fit for the wheels.
« Reply #2 on: 26 September 2011, 21:07 »
what do you mean by 'bottoming out' ?
And they're the same wheel bolts i was using for my VMR 710 alloys - now being used on mercedes AMG slot style alloys
The 14mm thread. about 38mm long. Tapered
~Mags~
« Reply #3 on: 26 September 2011, 21:10 »
Well if the bolt is too long it will be hitting the disc and not tightening up.
« Reply #4 on: 26 September 2011, 21:13 »
Essentially what i was saying, just never heard of the phrase bottoming out used with bolts - confused me.
I'll take off the adaptors tomorrow and bolt them to the wheels and see if they stick out or not. Cheers
~Mags~
Offline Grand Master Patch
« Reply #5 on: 26 September 2011, 21:13 »
They will 100% stick out around 3mm
« Reply #6 on: 26 September 2011, 21:20 »
That would explain why the backs are fine and the fronts not. Do you know where i can get wheel bolts from?
Near me i have a euro-car parts, wilco, halfrauds and unipart.
I've only ever bought wheel bolts online but really need my car this week so would be ideal to get it sorted tomorrow.
~Mags~
Offline Bellend
« Reply #7 on: 26 September 2011, 21:23 »
Just grind or file them down the 3mm or so. :)
« Last Edit: 26 September 2011, 21:50 by Bellend »
Where all my moneys went.
« Reply #8 on: 26 September 2011, 21:33 »
Exactly,take the adaptor off,put the wheel bolts through the adaptor,grind off the required amount and unscrew them,this will clean up the thread for you :wink:
Offline Dave_IOW
« Reply #9 on: 26 September 2011, 23:01 »
Grinding disk (used to sharpen chisels etc..)
Failing that, angle grinder..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
