Author Topic: brakes  (Read 4322 times)
Offline danhock
brakes
« on: 18 September 2003, 13:00 »
The brakes on my Golf Gti 16v Cabrio are poor..
Hard to push and fair amount of pressure needed to stop!
Feels like the servos dead... any suggestion, things to look for test?
Dan
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline richandhazel
Re:brakes
« Reply #1 on: 18 September 2003, 13:17 »
They sound normal to me! Mk1 brakes are well known for requiring a lot of effort to achieve adequate braking........you'll get used to them.
Offline danhock
Re:brakes
« Reply #2 on: 18 September 2003, 13:19 »
I'll end up with arms like popeye from steering and legs like tree trunks from braking...
Oh year the clutch pedal is stiff too!
Re:brakes
« Reply #3 on: 18 September 2003, 13:26 »
Yep, that's Mk1's for you..........couple that with that great engine and in your case even better engine and you've got your seat of the pants driving experience that you get from the Mk1.  ;D ;D
« Last Edit: 18 September 2003, 13:27 by richandhazel »
golfvr6
Re:brakes
« Reply #4 on: 18 September 2003, 14:50 »
Its that good old servo linkage  ;)
Offline AdamB
  • The Perfect Storm
Re:brakes
« Reply #5 on: 19 September 2003, 12:46 »
 I have to sympathise there. My brakes are poor at the best of times (I've had a couple of close shaves due to some fading) I have now decided to upgrade with a C&R brake kit - black diamond discs, predaotor pads and larger calipers, and maybe some braided hoses.
 No more adrenaline fuelled braking for me, now.
 Should be on the car in a few weeks, so I will let you know how it feels.
I don't own this anymore - I just can't be arsed to change the picture
Offline adyh
Re:brakes
« Reply #6 on: 19 September 2003, 14:55 »
VW brakes of that age are notoriously bad. I had a Mk2 polo a long time ago and the brakes were shocking. the car was 1.3 but VW never bothered to uprate the brakes from a 1.1 and by the way no sevro .
Offline tinman
Re:brakes
« Reply #7 on: 19 September 2003, 17:58 »
ok, heres a shot in the dark, from the school of "been there, done that, got crucified by a new part".
Rear Brake Compensator is screwed. The result is that the brakes just aren't sharp, and in a dire emergencies, or just simply braking, you need to turn to prayer to stop, rather than trusting your brakes.
This component has about 17 different names. You have been warned.
If it is my rear brake compensator thats buggered i'll tell you all when the car returns.
Tin
Offline bigkev750
Re:brakes
« Reply #8 on: 20 September 2003, 00:46 »
a simple check to see if your servo is working
engine off,press your brake pedal,start your engine keeping the pedal pressed,if the pedal goes down a few millimeteres once started then its ok.
OR press the pedal a few times with the engine running and hold it there switch the engine off and press a couple more times and the pedal should gradually become harder,if this fails you should go straight out and buy a mk2 GTI 8V
golfvr6
Re:brakes
« Reply #9 on: 20 September 2003, 13:06 »
Its not the servo thats bad, mk1 is notorious for the bushes wearing out on the cross linkage.
