Author Topic: brakes  (Read 4324 times)
Offline richandhazel
Re:brakes
« Reply #10 on: 20 September 2003, 16:35 »
a simple check to see if your servo is working
engine off,press your brake pedal,start your engine keeping the pedal pressed,if the pedal goes down a few millimeteres once started then its ok.
OR press the pedal a few times with the engine running and hold it there switch the engine off and press a couple more times and the pedal should gradually become harder,if this fails you should go straight out and buy a mk2 GTI 8V
Good advice there.......apart from the last bit of course :P Made me laugh though  ;D ;D
