Author Topic: Rattling noise after fitting spacers??  (Read 3261 times)
Re: Rattling noise after fitting spacers??
« Reply #10 on: 26 September 2011, 21:04 »
Is the spacer a tight fit onto the hub. :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 26 September 2011, 21:07 »
take a bolt out and measure it against a standard one. I'm with wayne on this one if the bolts are too long it flicks the abs ring and sounds like a rattle.
Offline Paul81
  • 2002 GTI Turbo
« Reply #12 on: 26 September 2011, 22:09 »
I bought extra bolts, just under 20mm longer than standard to bolt the wheel & spacer to the hub.
Is that the most secure way to do it or would I be better bolting the spacer to the hub first then bolting the wheel to the spacer?
Mods - Tinted windows, Mk8 Polo aerial, BBS RS2 alloys, -40mm Koni springs, Bilstein b4 shocks, VRS steering wheel, anni roof spoiler, R32 front bumper, rear anni valance, R32 side skirts.
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 26 September 2011, 22:44 »
as long as they're torqued correctly that is structurally more sound than bolt-on types.
Offline Paul81
  • 2002 GTI Turbo
« Reply #14 on: 26 September 2011, 23:48 »
I really don't understand why im having this problem.
Will any 5 x 100 spacers be ok or does it have to be a certain type for the mk4?
Offline houston
« Reply #15 on: 27 September 2011, 01:14 »
You shouldnt need longer bolts if your using bolt on spacers, the bolts aren't nipping the alloy to the spacer from sounds of it, whilst wheel is in air and nuts are tight can you check wheel is secure? Push and pull top of wheel.
Offline GunnerCP
« Reply #16 on: 27 September 2011, 02:23 »
what brand of spacers are these? did you buy them brand new?
Offline sprout99
« Reply #17 on: 27 September 2011, 10:22 »
from experiance you will need to remove the hub nut cover in centre of rear wheels
it won't allow the spacer to sit down fully on hubs
i've had your prob before
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Paul81
  • 2002 GTI Turbo
« Reply #18 on: 29 September 2011, 01:05 »
Finally solved the problem  :smiley:
This is a photo of my actual spacers, i had previously used the holes indicated in red, last night i removed them and used the holes indicated in green and no more rattling  :grin:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #19 on: 29 September 2011, 01:35 »
Lol this is kinda an epic fail  :laugh:
