Author Topic: Dash and door speakers  (Read 3508 times)
Offline Mart8V
  • I really should know better by now.....
« on: 22 April 2005, 20:09 »
Can I run the dash and door pods off the same output from the head unit?  At the moment have spliced and connected, but quality not great.  Head is a 4x45 JVC, and at the moment have standard speakers in dash and the Nokia door ones which came with the grilles.
Would I be better off with some mids and tweeters?!  What about two new sets?  Do I need a crossover for components?
Confused! :undecided:
Offline jv
  • Administrator
Re: Dash and door speakers
« Reply #1 on: 22 April 2005, 21:22 »
simple, cheapish solution would be to get a set of new full range (2 or 3 way) speakers for the door pocket position and give up on the dash top ones.
a bit more money, a set of components, that would come with the required crossovers. the mid would go in the doors and then the tweeters could be fitted either:
further up the door card
into the backs of the wing mirror plastic trim (like mine)
or into the dash top position
not too tricky hopefully :)
« Last Edit: 22 April 2005, 21:31 by jv »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Mart8V
« Reply #2 on: 22 April 2005, 22:23 »
Thanks for the info.  Will do some pricing up!
Offline golfpro
  • If in doubt, pay someone else to do it!
« Reply #3 on: 26 April 2005, 07:26 »
IMO its worth goin for the components. Iv got the focal polyglass in the front of mine and hidden them away behind the standard grills.
mmmm.....the element of suprise!!  :wink:
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
Offline hockeylad72
« Reply #4 on: 29 April 2005, 09:21 »
further to what jv and golfpro said,
you can get the grills from your lcal VAG dealer here are tha part nos you would need, as long as you have the door pockets with the pull out hinged bins.
grilles - 191 867 149 LN8  black in colour 2 required
screws - N0139649 again 2 required
nuts - N0386011 8 required these are exactly the same fixings as the rear 6 x 4 speakers
cost-
grilles £9.33 + vat each
screws £0.12 + vat each
nuts £0.10 + vat each
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 29 April 2005, 10:13 »
it's easy to make your own door pockets to take a larger speaker. I've started the how to in this section. :)
Mk4 Golf 150PD
Offline djta
« Reply #6 on: 29 April 2005, 16:29 »
Hi all - so to fir some 5 1/4" speakers where teh door pockets are, I need to remove the pockets and cut holes in the door, or is there something I can mount them too?
T
Offline hockeylad72
« Reply #7 on: 29 April 2005, 16:52 »
the grilles as per my previous post act as the mounting, depending on depth of speaker you use, you may have to cut door card for clearance.
Offline djta
« Reply #8 on: 29 April 2005, 16:54 »
Cheers mate.
Offline hockeylad72
« Reply #9 on: 29 April 2005, 17:04 »
have a look at this thread
http://www.golfgtiforum.co.uk/index.php?topic=19191.0
have a look at the rear speakers and the parcel shelf supports and you will see how the fit
