Author Topic: K03 or the k03s???? Searching......  (Read 4991 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: K03 or the k03s???? Searching......
« Reply #20 on: 24 September 2011, 17:20 »
052 - silenced (AUQ engined 1.8T?)
053 - non silenced (AUM engined 1.8T?)
058 - non silenced (new Beetle?)
Offline kstevens88
« Reply #21 on: 24 September 2011, 17:57 »
My engine is a AUM but apparently it's a 052??
Are you sure that's right?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 24 September 2011, 21:44 »
I have the 052 which is silenced and was from a Leon Cupra with the AUQ engine so I hope so. As far as I'm aware the AUM only came with the non silenced K03s but I may be wrong. It's easy to spot as it has a big metal part added to to outlet pipe
Offline kstevens88
« Reply #23 on: 25 September 2011, 19:06 »
Ok so I've been doing a bit of research over the internet and can across that apparently the AJM engines were factory fitted with a K03s however if they had been replaced in a garage they would have been fitted with a K03 for some reason!!!
I know that the previous owner the the owner before him had a turbo fitted so it's possible that it could have been fitted with a K03.....
If I was to buy myself the K03s would there be any different parts that I should by aswell?
Also is there any difference between the silenced and the unsilenced or would they both fit???
Offline kstevens88
« Reply #24 on: 25 September 2011, 22:38 »
That's AUM not AJM
