Author Topic: Help with strange issue please - AGU 1.8t  (Read 1387 times)
Offline master_oogwai
« on: 18 September 2011, 13:16 »
This has been an ongoing issue, but because it is intermittent, I have left it. I wanted to post this a while back, but I just wanted to make sure I am not going mad, so I have been monitoring this issue for a while and hope someone can shed some light on this one please?
Each time, the petrol gage reaches the point in the below pic and I accelerate fairly briskly, the car would pick up speed for a couple of seconds then holds back as if I pressed on the brakes. Their has been times when the engine seemed it was going to turn off. Only way I can get out of this is to either let go off the gas and then back on or pump the gas a couple of times. I have had two close shaves in the past when someone has been following behind me, I go and accelerate and this issue happens.
VAG-COM does not bring up any issues unfortunately. Anyone have any ideas what this could be?
Thanks
Offline vwblackmk4gti
Re: Help with strange issue please - AGU 1.8t
« Reply #1 on: 18 September 2011, 13:19 »
abit of an odd 1 there. maybe fuel pressure incorrect
Offline houston
« Reply #2 on: 18 September 2011, 16:18 »
crap in the tank pump?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 18 September 2011, 16:45 »
try a different fuel pump. ALL of the mk4 platform petrols use the same pump so you shouldn't have any problem finding one  :smiley:
Offline golf-sib
  • Турботазик
« Reply #4 on: 18 September 2011, 17:52 »
During acceleration only or is it when hard braking and hard cornering?
Pump could be on its way out, when was fuel filter changed last?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
« Reply #5 on: 18 September 2011, 18:59 »
It only happens under acceleration.
The fuel pump was replaced back in July 2010 and the fuel filter was replaced in February this year with a full service.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #6 on: 18 September 2011, 19:39 »
Poor return feed/flow not keeping the swirl pot topped up.  Try going around a tight around about 3 or 4 times when the fuel is low and see is she cuts back on power.
Did we fit a new pumpd or used unit?
 01455 617233
« Reply #7 on: 18 September 2011, 20:22 »
You guys did not replace the pump. I took it to a garage near my work to have a new one fitted. When you guys had the car afterwards to put stage 2 back on, you guys replaced a hose as it had a kink in it and you replaced the fuel filter as it was covered in brown gunk.
I will try what you suggested tomorrow Nick before I refill the car up and see what happens. Thanks.
