Author Topic: ABF Gearbox  (Read 3529 times)
Offline tech1889
  • Mk2 GTI FTW !!
ABF Gearbox
« on: 16 September 2011, 15:36 »
Trying to mate my 02A to my ABF to fit into my mk2... Thing is i cant seem to get my gearbox to fit.. it just doesnt seem to line up at all.. ive tried lining the 2 lugs up on the block but still nothing its starting to annoy me now..
can anyone help ?
has anyone got decent pics of a ABF block and gearbox mounted together ?
Thanks
Offline Dan_GTi8v
Re: ABF Gearbox
« Reply #1 on: 16 September 2011, 19:16 »
Do you mean the bolt holes don't line up? The 02a is designed to fit lots of engines so you don't don't need all the holes lined up i think i only have 3 on mine
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #2 on: 16 September 2011, 19:18 »
just cant get it to line up so it looks half decent im just confused
Offline Ess_Three
Re: ABF Gearbox
« Reply #3 on: 16 September 2011, 19:23 »
Daft question perhaps. but it is the gearbox for the engine isn't it?
It's not a 6 cylinder 02A?
..but gaining motorcycles.
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #4 on: 16 September 2011, 19:36 »
How would I tell the difference mate ?
Offline Ess_Three
Re: ABF Gearbox
« Reply #5 on: 16 September 2011, 20:11 »
What's the gearbox code on it?
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #6 on: 16 September 2011, 21:09 »
Can only see o2a on the outside where will the whole code be located ?
Offline tshirt2k
  • Been there...Done that...
Re: ABF Gearbox
« Reply #7 on: 16 September 2011, 21:31 »
There's a flat section near the shift tower. Clean it off and you should see the code.
Mk3 ABF 16VT Megasquirt V3
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #8 on: 16 September 2011, 21:34 »
Thanks will do it in the morning and post up  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #9 on: 17 September 2011, 11:16 »
2 part numbers ive found,
o2A 945 413 B - on the shift tower - And google says this is the reverse light switch
o2A 301 107 C - on the inside of the housing - Quick google tells me its a 5speed trans housing
any ideas ?
« Last Edit: 17 September 2011, 11:18 by tech1889 »
