Author Topic: ABF Gearbox  (Read 3531 times)
Offline Ess_Three
Re: ABF Gearbox
« Reply #10 on: 17 September 2011, 13:00 »
On the flat section where the shift tower bolts on, there should be a 3 digit code. DPA or similar.
I think DPA is the Mk3 16v gearbox.
You may have ro use some emery paper or a scraper to get the area clean and readable.
I *think* the Golf VR6 'box is CCM...and no use at all.
« Last Edit: 17 September 2011, 13:03 by Ess_Three »
..but gaining motorcycles.
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #11 on: 17 September 2011, 13:14 »
you were right turns out to be a o2a vr6 box  :cry: there is no way this will fit is there ?? its a o2a CCM box
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #12 on: 17 September 2011, 13:19 »
Right on the hunt for a new gearbox  :angry:
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #13 on: 17 September 2011, 14:24 »
any idea of codes that will fit ive found a DFQ code one ?
Offline tshirt2k
  • Been there...Done that...
Re: ABF Gearbox
« Reply #14 on: 17 September 2011, 15:28 »
Any 4 cylinder 02a will fit, but depends on the ratios you need.
Mk3 ABF 16VT Megasquirt V3
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: ABF Gearbox
« Reply #15 on: 17 September 2011, 15:29 »
Think DFQ is an 020 box is it not??
Offline tshirt2k
Re: ABF Gearbox
« Reply #16 on: 17 September 2011, 15:33 »
Yep 020
DFQ 8/95 - 7/96 Golf, 8/95 - 7/96 Jetta, From '93 115hp, Large input shaft   3.45 1.94 1.29 0.97 0.8 3.67
Search in this knowledge base for all the 02a codes. You may find a box with a 3.9:1 ratio would be better for a mk2.  :wink:
Even an 02J from a mk4 can fit and may even have some good ratios to choose from. Don't go putting any old box that fits on. It may spoil your driving feel.
« Last Edit: 17 September 2011, 15:44 by tshirt2k »
Offline tech1889
  • Mk2 GTI FTW !!
Re: ABF Gearbox
« Reply #17 on: 17 September 2011, 15:52 »
What box would you recommend mate ?? i just want something cheap at the moment so i can get the car running and MOT'd and can change after if need be.. can you also run seat cable clutch on a mk4 box ?
Offline Ess_Three
Re: ABF Gearbox
« Reply #18 on: 17 September 2011, 16:43 »
Nope...not unless you swap the casing for a 4 cylinder casing...and even then the FD ratio is awful for a 16v.
Best just flog it and look for a DPA or other 4 cylinder 'box.
Offline tshirt2k
Re: ABF Gearbox
« Reply #19 on: 17 September 2011, 16:49 »
Ah. Also depends on what driveshafts you have, as they are different sizes. Although some are interchangeable. Do it once and get the box you need. CDA/DPA MK3 16v boxes can be had for £30-£60 if you search. Mk4 boxes can be used with the cable IIRC.
