Author Topic: Missfire on an 1.8T AGU engine code?  (Read 36431 times)
Offline richw911
« on: 15 September 2011, 21:23 »
If your AGU has developed a missfire (usually on on cylinder 3) the ignition module is a very likely culprit.
The early 1.8T's don't have a management light and this fault doesn't usually throw a fault code. The coilpacks on an AGU are rock solid because they don't have amps built into each coil like the newer 1.8t's (AUM, AUQ).
For the AGU this is controlled by one ignition module.
As a first step :
Make sure the coil packs, the wiring to them and the spark plugs are all ok (Swap the coilpacks and spark plugs to see it the missfire moves to another cylinder)
If not it could well be the ignition amp AKA  Ignition Control Module, this is located on the airbox at the rear.
Two screws and just unplug and replace.
Ignition Control Module, part numbers  Bosch 0227100211 or 4D0905351.
Eurocarparts list these as "TCI MODULE" (Transistor Controlled Ignition) part no 415440120
You can get one from Euro car parts and use the forum discount  :smiley:
http://www.eurocarparts.com/ignition-modules
£66.60 with forum discount  :smiley:
The writer of this guide and GolfGTI.co.uk accept no responsibility of damage to your car when using this guide Use at your own risk.
« Last Edit: 18 December 2011, 11:37 by richw911 »
Offline golf-sib
  • Турботазик
Re: Missfire on an 1.8T AGU engine code?
« Reply #1 on: 15 September 2011, 21:32 »
Rich, can you kindly delete this, as AGU's don't have problems  :laugh:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline richw911
« Reply #2 on: 15 September 2011, 21:36 »
That is very true  :laugh: :grin:
Offline Rhyso
« Reply #3 on: 15 September 2011, 21:36 »
That is so not true  :laugh: :grin:
 :lipsrsealed:
Offline richw911
« Reply #4 on: 15 September 2011, 21:38 »
 :lipsrsealed:
Other than my waterpump name a fault ive had on my engine..... :laugh:
Offline Rhyso
« Reply #5 on: 15 September 2011, 21:40 »
 :lipsrsealed:
I was referring to others who do suffer problems  :tongue:
Looked at one today where if you leave it idling it starts hunting  / mis-firing almost yet no fault codes came up  :huh:
Ignition amp or MAF??  It cut out several times after I looked at it  :sad:
Offline richw911
« Reply #6 on: 15 September 2011, 21:41 »
 :lipsrsealed:
 :laugh: TB clean first if it is a missfire id say amp  :smiley:
Offline golf-sib
  • Турботазик
« Reply #7 on: 15 September 2011, 21:41 »
I know the forum member, he messaged me instead off you Rhyso :embarassed:
I suggest maf or a cylinder's down due to coil or amp as well  :smug:
1.8T AGU..
R135
  24
Offline Rhyso
« Reply #8 on: 15 September 2011, 21:43 »
 :lipsrsealed:
Its johnomk4s which has a weird TB fitted lol
http://www.golfgtiforum.co.uk/index.php?topic=205773.0
Amp was my idea too as its been relocated to near the suspension turret due to a cone filter being installed
Offline richw911
« Reply #9 on: 15 September 2011, 21:46 »
 :lipsrsealed:
Ah amp if its been moved probably got too hot  :smiley:
