Author Topic: noob question proberbly  (Read 2696 times)
Offline mcgee9t2
« on: 09 September 2011, 11:26 »
My sub is in a ported box. but the sub is mounted inside the box about 4 inches inside with a perspects sheet infront of it. was gonna make a custom box and boot build. but just had a thought. Basically. does the perspects make a difference. i.e could i just cut 4 inches off the front of the box? Will try find a pic of the sub in question on myy lunch. cheers
Offline Len
Re: noob question proberbly
« Reply #1 on: 09 September 2011, 12:43 »
Depends if the perspex area is part of the "sound box" volume.
How much is behind the speaker?
www.sas.org.uk
www.the-ace.org.uk
Offline mcgee9t2
« Reply #2 on: 09 September 2011, 13:00 »
it appears to be in the middle. thats the part i cant figure out if its supposed to be part of the box to give it better sound.
though the perspects is held on by screws so i cant see it being a problem if i remove it and cut the box in half so the sub sits on the top.
Offline mcgee9t2
« Reply #3 on: 09 September 2011, 13:13 »
hopefully this pic will work?
Offline mcgee9t2
« Reply #4 on: 09 September 2011, 13:22 »
Uploaded with ImageShack.us
hopefully this one should work seens the last one didnt....
not very clear but you get the jist, the sub is mounted in the middle of the box.
Offline Len
« Reply #5 on: 09 September 2011, 13:53 »
Is that the amp on the side?
I assume the silver side is the port?
If so you cant reduce the length of that.
TBH get a decent box sorted.
www.sas.org.uk
www.the-ace.org.uk
Offline mcgee9t2
« Reply #6 on: 09 September 2011, 14:05 »
Yeah amp is on one side. the silver part is the port yes
this was going to be a temp sub but sounds good for how much i bought it for so dont see any point in upgrading. the port wouldnt be reduced no. just the box infront of the sub wpuld be cut off
Offline joe skandal
« Reply #7 on: 18 September 2011, 04:36 »
9 times out of 10 everything you see is relevant to the acoustics on these sort of things. I.e, you will be basically f**king the speaker if you start cutting bits off. That what makes the speaker the speaker, the box the woofer is enclosed in...
-Joe
Turn on, tune in, drop out..!
