Author Topic: rear coilivers/shocks  (Read 1041 times)
Offline mk3tony
« on: 04 September 2011, 15:37 »
Hi Guys,
I'm changing all my coilovers as they're sh!t, the fronts i'm fine with, going to borrow an impact gun from hire station for the top nut, but my query is, how can i undo the rear top nut without the shock spinning, when installing, i done by hand and just used mole grips and a spanner, but every guide i read just says undo it, no mention of shock spinning, am i doing something wrong?
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline DanChave
Re: rear coilivers/shocks
« Reply #1 on: 04 September 2011, 16:04 »
Hi Guys,
All you should need is a spanner and molegrips like you said :) Thats all I used!
« Reply #2 on: 04 September 2011, 16:36 »
The rear shock should have a small square part at the top that you can hold with a small spanner.
Offline DanChave
« Reply #3 on: 04 September 2011, 18:02 »
Or that would work!  :smiley:
Offline gasketface
« Reply #4 on: 04 September 2011, 18:11 »
Iv'e changed loads of shocks on mk3 Golf.Iv'e not yet had one that spun when trying to undo the top nut,nor have i ever had to use anything to hold the centre shaft.I just undo them while the car is still on the ground,using a slightly curved spanner and wack it on the first turn to jolt the nut from full lock.
Do'nt forget to reset your camber on the fronts  :smiley:
Offline mk3tony
« Reply #5 on: 04 September 2011, 18:13 »
so brute force could be the answer! haha
yeah i usually hold the square bit, thanks guys!
