Author Topic: Do i need an external oil cooler? 8v 155bhp  (Read 3280 times)
Offline lew666
« on: 01 September 2011, 18:06 »
Basically ive got an 8v digi engine heavily modified which has been dyno'd at 155bhp,
Ive no experience with cooling and was wondering if ill need an external oil cooler or will the standard water cooled one be up to the job?
Offline Sam
  • Sam I am
Re: Do i need an external oil cooler? 8v 155bhp
« Reply #1 on: 01 September 2011, 18:19 »
Im running at 240bhp and dont need one, you should be fine.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 01 September 2011, 18:24 »
External oil cooler is better than none, especially if you exploit your car on a regular basis, a 10 row cooler, should be more than sufficient for your requirements...
Thom
Offline mk2bal
« Reply #3 on: 01 September 2011, 19:10 »
I'd say it depends on the temps your oil gets to..? From what I've read 100-120 ish is ok, but you don't want to go much higher.. Have you got an oil temp sensor on mfa? If so what does it read?
Offline lew666
« Reply #4 on: 01 September 2011, 20:10 »
Sorry forgot to mention the engines not in the car yet
Offline Sam
  • Sam I am
« Reply #5 on: 01 September 2011, 20:18 »
Ah ok, well when its in and ran in you shouldnt be seeing oil temps above 110. If you do its very easy to install a cooler post engine install. As thom said you only need a wee one and a sandwich thermo plate with feed and return.
Offline lew666
« Reply #6 on: 01 September 2011, 20:23 »
Nice one, cheers matey
Offline Andy P
« Reply #7 on: 01 September 2011, 21:55 »
What's the engine spec?
Offline lew666
« Reply #8 on: 01 September 2011, 22:45 »
1.8 bored to 2.0l with longer stroke crank with new bearings rings and gaskets/seals,
Fully balanced,
New std compression pistons (not forged)
High flow oil pump, windage tray and baffled sump,
Head & block skim to achieve 11.1:1 CR,
Re worked TSR pack C head with 40/35mm valves and solid lifters,
Piper Vernier,
Kent 282 cam,
Refurbed dizzy with altered advance curve to match cam,
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 02 September 2011, 08:15 »
Run it with an oil temperature gauge.
As above, if it's topping out above 110-115 deg C then fit a cooler.
If not, don't bother.
Retain the oil:water cooler - it helps warm the engine oil faster, prolonging the engine's life.
